924 Accelerator pedal, what am I missing?
My 924 seems to be missing a roller of some sort on the accelerator pedal.
The pedal is there and so is the rod the hangs down but there is nothing on the rod, there is a grouve for a circlip but no runner or roller for the pedal, what should be on there??
Cheers
Dan
Old 06-13-2006, 03:03 AM
924RACR's Avatar
Nothing... it just clips through the tab on the pedal. You do have the tab on the pedal with the slot, correct?
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 06-13-2006, 07:01 AM
Yes, but the bar that goes through the clip seams to get stuck and jams the throttle on, there are definatly markers for some kind of plastic roller/ washers and a circlip (c-clip)or something that appears to be missing. This is on a standard 924 RHD UK car.
1981 RHD 924 2.0L non turbo
Old 07-11-2006, 07:52 AM
924RACR's Avatar
Yes, as I recall there should at least be a washer on the end before the circlip, if not also a washer on the end near the bend. Make sense? Stack-up should be clip, washer, plastic pedal tab, washer.
Vaughan Scott
http://www.924.org
Old 07-12-2006, 07:15 AM
