924 Accelerator pedal, what am I missing?
My 924 seems to be missing a roller of some sort on the accelerator pedal.
The pedal is there and so is the rod the hangs down but there is nothing on the rod, there is a grouve for a circlip but no runner or roller for the pedal, what should be on there?? Cheers Dan |
Nothing... it just clips through the tab on the pedal. You do have the tab on the pedal with the slot, correct?
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
1981 RHD 924 2.0L non turbo |
Yes, as I recall there should at least be a washer on the end before the circlip, if not also a washer on the end near the bend. Make sense? Stack-up should be clip, washer, plastic pedal tab, washer.
