Spark Plug wires
Just received new plug wires (Magnecor) to replace on my 1989
944S2.
The old wires had a ground from each. The new ones do not.
Are the grounds to reduce radio interference or are they needed for other reasons? The car is a track only car so I do not care about the radio.
Old 10-14-2006, 06:05 AM
SoCal Driver's Avatar
Call the place you got the Magnecors from.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-14-2006, 06:41 AM
Normal spark plug wires aren't supposed to have a ground. Your old ones were probably the Nology wires with the inline capacitor - they have a ground lead which is indeed to reduce EMI since the capacitor wires are more prone to generate noise.
On a second note, the Magnecor wires are crap. I had a set, and the connectors deteriorated and fell apart in less than two years. Send them back and get a set of OEM wires, or at least some wires with the OEM Beru connectors - I believe Paragon Products has some "high performance" wires that use the proper connectors.
Old 10-14-2006, 11:51 AM
Politically Incorrect
onZedge's Avatar
todd951-
The Magnecor wires are not crap, the rubber boots are crap. Mine are falling apart after about a year. Glad I got 'em cheap. I thought I did my research well enough. I HATE buying things twice !!
Edek
'87 924S
'91 535i
Old 10-15-2006, 11:48 PM
Well, yes the rubber boots are crap. When I said the wires are crap I meant the whole assembly
Old 10-16-2006, 07:13 PM
Try Jacob's energy wires form performance parts.com.. 8.5mm for under $70.00. and like I said before I am not a salesman for them I have used thier product...
Rodney S. Bennett
Old 11-30-2006, 04:50 PM
