Unhappy rear cam tower gasket
HELP!!! I have a small oil leak on the rear of my engine. It looks like it is dripping down from the rear of the valve cover gasket. Someone said it may be the rear cam tower gasket. I had to tighten 3 bolts where the engine lift is on the rear earlier but I still have a small leak there. Does anyone know the part number for this gasket? Or know where else it could be leaking from? It seems to be leaking straight upon the header. I did remove the engine life assembly then re-install it but it still is leaking not as bad.
thanks,
Rodney
Rodney S. Bennett
Old 12-05-2006, 04:33 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
928-105-189-02-M208
1995 993 C2
Old 12-05-2006, 04:45 PM
That Guy
Techno Duck's Avatar
That gasket often is the problem because its made out of cork. Its one of those few cheap parts for these cars...
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-05-2006, 05:29 PM
Hoss Ghoul's Avatar
Send a message via AIM to Hoss Ghoul
Common leak, I've had it, friends is leaking as well. $40 at a shop, so not much.
1987 924S
2000 Camaro Z/28
Old 12-06-2006, 12:55 AM
You can replace the gasket with a new one or you can remove the gasket and use RTV sealant instead of a gasket (after cleaning up the sealing surfaces). I think Loctite 574 anerobic sealant would also work but a tube of that costs more than the gasket.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 12-06-2006, 06:15 AM
meister member
speedracing944's Avatar
If it is the cam tower gasket it is much different than the cork gasket on the cap on the back of the cam tower. The cap which is retained by 3 bolts will be easy to change where as the cam tower gasket is a little harder and more involved. You will need to pull the cam tower which means you are also removing the cam and balance shaft belts. Check out www.clarks-garage.com for the write up.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 12-06-2006, 11:05 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Just get it fixed! Oil dripping on headers = very bad fire. I have a friend who figured that out the hard way. Very very poor design by Porsche. I put a metal shield above my headers to keep the oil from dripping directly on my headers if this ever happens to mine.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-06-2006, 12:23 PM
Thanks for the comment on fire hazard. I have the same leak at the cam tower and at start-up the header smokes a little until the oil burns off. I never figured there would be enuf oil to cause an actual fire, maybe I'll rethink that one and put the repair on the top of the list.
There goes all the careful belt tension that I just spent so much time getting right. Oh well, good practice I guess.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 12-09-2006, 08:52 AM
You might be able to change it without pulling the cam tower. I can't remember how much room is back there.
Tom
Old 12-09-2006, 09:46 AM
meister member
If you pull the cam tower it would be a good time to replace any colapsed lifters.
The 2 times I pulled my cam tower I always wanted to get a more aggresive cam from webcam. But I never do it. I realy should one day.
Speedy
Old 12-09-2006, 04:19 PM
Back from Beyond
You can get to the cork gasket without pulling the cam tower, but it's tight. Maybe change the cork gasket first and see if that cures things before you pull the whole cam tower.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 12-10-2006, 09:07 AM
Thanks guys, I'll take a hard look at it this week. I havn't pinned down the exact location of the leak yet.
Jon
87 924S
82 924-Gone.
Old 12-10-2006, 11:30 AM
Send a message via AIM to TheCooler
make your own gasket
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 12-10-2006, 12:40 PM
I just took my cam tower off because of the same leak. I thought the leak was from the "valve cover gasket" (ha ha). Went ahead and pulled the cam tower off and found that the leak was acutually that little gasket at the back. I made my own and sealed it up with some silicone. You probably have enough room to replace it without pulling the cam tower.
Rusty
'83 NA 944
Old 12-10-2006, 03:52 PM
