winter-hater club member
nynor's Avatar
what is the trick to getting the spring loaded
belt tensioner off? i need the thing off, i believe to change the timing belt.
thanks!
"COOL PRIUS!" - Nobody Ever
Old 03-05-2007, 06:51 PM
SoCal Driver's Avatar
Loosen the bolts at the piviot and at the slot, pry the arm back and tighten it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-05-2007, 06:55 PM
nynor's Avatar
yeah, i did that. don't i need to get the thing entirely off to change the belt?
Old 03-05-2007, 07:01 PM
That Guy
Techno Duck's Avatar
Three nuts hold it onto the block, it slips on over studs. Use an inspection mirror to figure out where they are.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-05-2007, 07:06 PM
nynor's Avatar
oh boy. i need a mirror for this? thanks!
Old 03-05-2007, 07:09 PM
That Guy
Its not they are hard to reach, its just they are hard to see due to the position. Of course you could take the radiator and the fans out for a clear shot.
Jon
Old 03-05-2007, 07:27 PM
nynor's Avatar
i think my last post sounded bad. thanks for the information. i'll take a look tomorrow.
Old 03-05-2007, 08:05 PM
Compress the arm and tighten it. Take the idler pulley off -- one bolt. Release the tension on the arm. You do not have to take the arm off. Don't loose the special oblong washer or put it back on wrong -- there is an indexing tab that locks the oblong washer into the casting.
With the tension off of the arm you can get to the three bolts that hold it on.
Old 03-05-2007, 10:58 PM
There are three hex nuts holding the tensioner assembly to the block.
Do not compress the tensioner yet until you have removed the hidden nut beside the tensioner roller.
Remove the hidden nut first, then compress the tensioner, then remove the other two nuts holding the tensioner assembly.
Then you can pull out the tensioner assembly.
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 03-06-2007, 04:59 AM
IF you can get to the "hidden" retainer with out releasing the tension on the arm.
Old 03-06-2007, 07:39 AM
nynor's Avatar
ok, just to be sure: do i have to remove this part to replace the belt?
Old 03-06-2007, 10:07 AM
Redline Racer
HondaDustR's Avatar
You don't have to, as long as you compress it far enough to leave enough room to work the belt out.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 03-07-2007, 06:14 PM
And take the pulley off the end of the arm.
Old 03-07-2007, 06:22 PM
That Guy
I am a 'veteran' of 6 belt jobs now, let me just say its alot easier to get the old belt off and the new one on by taking the tensioner off. Its only 3 nuts.
Jon
Old 03-07-2007, 06:32 PM
Never said NOT taking the whole unit off was easier. Trying to answer a thousand questions. Time to cut bait.
Old 03-07-2007, 06:53 PM
That Guy
I didnt mean that towards anyone. I was just simply saying in my experience its much easier to just take the entire thing off.
Jon
Old 03-07-2007, 06:59 PM
I've seen newbies take the whole thing apart with the spring and arm flying off to hide in dusty corners. Also over compressing the arm so that it covers one of the three studs/nuts and using a pry bar because it's "stuck". Just don't loose the obround washer and put it back on correctly if you do.
Old 03-07-2007, 07:06 PM
nynor's Avatar
ok. i have to change the roller as well. they are all worn. how about just taking the roller off and leaving the rest of the assembly attached? or will that be an even bigger PITA?
Old 03-07-2007, 07:40 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
It's been my experience that removing the whole assembly is what worked best for me.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-07-2007, 07:56 PM
That Guy
Seriously, just take the damned thing off! Its 3 nuts!
You need to hold a bolt on the opposite side anyhow.
Jon
Old 03-07-2007, 07:59 PM
