Send a message via Yahoo to 912E TKT
Question Someplace that checks 968 Alternators
Hi,
I pulled my alternator and tried to get it checked at the local Kragens. They couldn't do it.
Anyone out there in the Pasadena CA area know where to get a 968 Alternator checked around here?
Steve Patrick
92 968 Cab
76 912E Sunroof Coupe
68 912 Targa
68 911 Coupe
Old 04-09-2007, 08:50 PM
bearone2's Avatar
i'm surprised they couldn't check it.
i think you might've run into someone who didn't know what they're doing.
many auto parts stores have universal type stands that accomadate most alternator/starters.
call another store and see if if you get the same response.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 04-10-2007, 12:16 PM
Okay so I found a rebuild shop on Foothill in East Pasadena called One Stop Auto Electric. They tested the alternator and it was cooked. They are doing a rebuild on my old one and it will be ready by 4:00 today. The rebuild is backed up for a year and cost 160.
Steve Patrick
92 968 Cab
68 912 Targa
68 911 Coupe
Old 04-10-2007, 01:09 PM
Cars & Coffee Killer
legion's Avatar
It's just a standard Bosch alternator. The same unit was used on Audis and Volkswagons. I had mine rebuilt a year ago for $70--but I did supply the voltage regulator.
5 liters of VVT fury now
-Chris
Old 04-10-2007, 01:41 PM
I made the mistake of saying the word Porsche
Steve Patrick
92 968 Cab
68 912 Targa
68 911 Coupe
Old 04-10-2007, 01:42 PM
legion's Avatar
Yep, I told the shop mine was from an old VW.
(Sometimes that even gets you sympathy.)
-Chris
Old 04-10-2007, 01:58 PM
Can anyone tell me which way to re-wire the starter on a 968? Does the largest cable attached to the upper or lower of the two primary connections on the solenoid?
Steve Patrick
92 968 Cab
68 912 Targa
68 911 Coupe
Old 04-11-2007, 07:44 PM
legion's Avatar
When I did it, I recall that the cables on the back of the alternator had either a large hole and a small hole, there was a corresponding large post and small post on the back of the alternator. (I believe the late 944 and 968 used the same alternator, correct?)
-Chris
Old 04-12-2007, 06:00 AM
Hi
Yes I see that there is only one way to wire the alternator, my question was about the Starter on the 968. I just need a double chek on where the two larger cables go on it.
Steve Patrick
92 968 Cab
68 912 Targa
68 911 Coupe
Old 04-12-2007, 06:46 AM
