944 Oil Recommendation
Hello,
I have an '87 944 that I do not have the owners manual for. Can anyone tell me what the manual says for recommended oil weight, type, and quantity. Someone recommended that I use 6.3 Quarts of 20w-50 Castrol or 15w-50 Mobil 1 and I chose to try 20w-50 Castrol synthetic blend because it's cheaper then Mobil 1. The pressure gauge usually never drops below 4 bar to maybe just below that on a hot day. From what I've heard it should read around 2.5 - 3 bar when completely warm so this weight seems a little heavy to me. Also can anyone recommend an oil and weight that they have found works best or should i just try a lighter Castrol synthetic blend. Thanks! -Tim |
Castrol 10-30 (not synthetic)
1975 - 914 1.8L Dual Weber 40's & MSD Ignition 1986 - 944 2.5L (SOLD) |
I run 15w50 Mobil 1
87 944 72 914 Sold 84 944 Sold 85.5 944 Sold 78 924 (first car) RIP |
I got this from my 85.5 manuel, hope it helps. I think Mobile 1 is the best, but...... each to his own.
![]() ![]() hope you are able to read it. if not let me know and ill answer it for you.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
That Guy
If you have summers like the NYC area, run at the very least a 40w oil. If your car see's any type of track use, stick with a 50w.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Thanks for your help everyone. Special thanks to thekidd that's going be be helpful. It seems like, even according to the manual, 40 weight is the very least to go. Can anyone tell me what their oil pressure gauge reads. With 20w-50 the lowest I have ever seen it go was 3.5 Bar driving around on a 98 Degree day but normally it likes to stay around 4 Bar. Seem a little high?
Not Special
I'll drop down to 2/2.5 bar on hot days with heavy driving, Castrol GTX (Dino, not synthetic) 20W-50.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen Former: 1985/1 Porsche 944 - Graphite/Black |
I run Mobil 1 15/50 since they don't make 20/50 any more. As for pressures, the reason I switched to only synthetic is that one day after making a few hard runs on some Valvoline 20/50 the gauge dropped to 3 bar. I immediately went to Mobil 1 and since then the gauge has stayed pegged at 5 bar (except when shifting where it is supposed to make a little blip) until I had a track day last month and it ran around 4-5 bar for the last two sessions. There is nothing wrong with it being pegged on 5 bar. Higher oil pressure is better from my experience with my 944. It is not like the 911 that makes 1.0 bar per 1,000 RPMS... totally different oiling system.
Yes, Castrol is a little cheaper, but I have tried most of the stuff out there and Mobil 1 is the only one that keeps full oil pressure even after running extremely hard.
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
In over my head
Your car seems normal. I get the same type of readings as you using Amsoil 20w50.
Fergus 86 951 Graphite Metallic 86 944 n/a Garnett Red Metallic (SOLD!) 74.5 Triumph TR6 (restoration project) 05 Subaru Legacy (winter car) |
Non Compos Mentis
I use 15/50 Mobil 1 in the 944 race car, so just to keep things simple I use the same in the 944 street car.
Castrol GTX 20w50 in summer and 10w40 in winter
Andy D. Currently driving 2005 Audi A4 Currently driving 2006 Ram 1500 sometimes |
Thanks everyone.
Just out of curiosity, has anyone noticed a difference in pressure when using different oil filters? From the last few oil changes I have done, using the same oil, I noticed when I used a Mann filter the pressure idling was higher then when using a Mahle. |
ban the spammer above me.....
anyways! i use Mobile 1 synthetic 5w30 all year round, ill drop down to 1.5 or after running hard, 2 bar with normal driving and highway. 4 bar at 4k rpm. what i was told is that ZINC is the needed additive. and that redline is the way to go for that. it seems to be a true high quality oil, although ive never used it. also you can use a little ZDDP additive to raise the Zinc levels. i know the older muscle crews use it and sware by it im thinking about going to a thicker oil....i think the 5w30 is a little thin for all year run, especially with the amount of bars im getting. im thinking a 10w30 synthetic might be better, i dont think going back to Dino oil is a good choice once a synthetic was used. i think ill add a little ZDDP just to be sure
1984 944 - black exterior, black/tan/brown interior (somehow it works....) 100K or so miles Last edited by phil823; 12-20-2009 at 02:09 AM.. |
[QUOTE=HTraftrepe;5080054]Hi,
[url=http://www.hammondneighbors.com/]CHEAP KLONOPIN - ![]() ![]() Warning this site "CASTRATE" spammer. Use 20w50 for years in my 944 now using same in my 968 ,if cold use 10w40.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
I've been using 15W50 Mobil 1 for over 10 years...no leaks... everything good. However, I don't run the car in winter.
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
Custom User Title
Another +1 for Mobil 1 15W50. I was having pressure problems in my 83 NA and this cured it.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Royal Purple 10w40.
I think the engine is quieter. landrover88
1978 911sc cpe 1986 944 N/A sold to pelican 1965 series 2a 88 landrover sold 1964 series 2a 88 landrover sold 1988 944 white. sold |
Mobile 1 0w40 in my car overall. Maybe Mobile 1 15w50 in the summer if I am doing lots of track (I also have an oil cooler).
-Randy 1984 944 -Race car project 1993 968 coupe- Amazon Green |
Hugging the curves
Right now I'm using Rotella oil for the 944 I bought about a month ago.
I've been thinking about going synthetic since every car I've owned I converted to synthetic with stellar results. But all I hear is that these old cars need zinc and blah blah. Not that I'm not aware of the differences in oils from over 20 years ago but todays oils are better in their lubing properties compared to the old oils. This thread seems to be a good idea of what works and so far have seen nothing bad about using a synthetic oil. Recently, I've been a big Royal Purple fan and now using it in all cars except the 944. Any other fans of the Royal Purple brand for the Porsches? Listening and subscribed. |
Also put Royal Purple in the Transaxle of my 88 n/a.
I think it works out well for my cars. My 86 runs Purple in the crankcase but regular in the back . I am going to replace the Transaxle to Purple next week. It has a bit of a rattle at times. I hope for some improvement.
| Tags |
| 1987 , 944 , oil , weight |
