Gauge Cluster
Is there any way I can separate the transparent piece from the actual gauge cluster. It's stuck pretty tight! Is it glued on or you can pry it apart? Thanks!
Stock 89' 951 Last edited by Its_Scott; 07-23-2008 at 08:26 AM.. |
unindicted co-conspirator
I think it's glued on, but if you remove the gauges from the housing, you can CAREFULLY use a dremel tool & cut the pieces apart
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Quality
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
In over my head
It can be done with a sharp exacto knife and very gentle prying. Mine was not glued all the way around - rather it was glued at different points - similar in concept to stitch welding.
Fergus 86 951 Graphite Metallic 86 944 n/a Garnett Red Metallic (SOLD!) 74.5 Triumph TR6 (restoration project) 05 Subaru Legacy (winter car) |
Thanks for the info. So after disassembling the unit, how would you guys put it back together?
Stock 89' 951 |
Try a couple of dabs of plastic model glue
In over my head
I think that I used silicone (or was it super glue gel). Both would work.
