Quick (basic) question
Recommended oil grade for a 924s is???
Any strong feelings on brand etc? Thanks |
Just thinking out loud
20w-50. Depends on where you are, though. If you change your oil regularly, it may not matter, but some don't. If that's the case, go with gear oil 85w 90, but only when it's hot out.
Seriously, what's the climate like? Will it freeze in the months coming?
83 944 91 FJ80 84 Ram Charger (now gone) |
Thanks for the quick response.
I'm in SoCal, pretty mild in the winter and warm in the summer. Manuals haven't arrived yet so thanks for bearing with me on the question and you'd be surprised at how little on this topic Google comes up with... Thanks! Last edited by tdskip; 10-03-2008 at 08:57 PM.. |
Your climate is not as extreme, but I"d go with 20w-50 anyway. Pick your poison on the brand. Mine has seen many, but mobile one it will never see.
Welcome!
Thanks!
You bet!
Proprietoristicly Refined
I use Castrol GTX 20-50 summer and 10-40 winter. Arizona car. I agree with Matt.
tdskip, "Manuals haven't arrived yet so thanks for bearing with me on the question and you'd be surprised at how little on this topic Google comes up with..." If you need additional information and become an expert: http://forums.pelicanparts.com/showthread.php?t=367300&highlight=engine+oil+thread GL John_AZ 1988 924S + 1987 924S |
What would Darth Vader do
I've been using Valvolines racing 20-50 with regular oil changes. Here in so cal. the weather can be rather irratic , from the 100's and above to 50-60 degress the next day. The 944 can run pretty hot.
Also, if you were to call the local P dealership, they recommend 20-50 Where in So Cal are you located?
1983 944 (2002 to now) 3-924's (Sold) 1967-912 (Traded) NEVER put a used water pump in your car... |
Thanks guys.
Gordon - I'm in Lake Forest. Do the 944 and 924S guys ever get together? |
One apex at a time
My 924s really likes valvoline 20-50 dyno juice. In fact many of the little oil leaks I had running synthetic went away. I just am very careful to change it every 2500-3k. I have used 10-40 and 10-30 the pressure was a bit lower than I liked. 37psi where as the 20-50 it is at 50psi. both these #'s are with water at 180-190F with oil temp at 80c
what about oil for a car (944 n/a) that sat around for 3 years without being driven? im about to dump in 10w30. the weather is typical to cold climate as Im in MONTREAL, Canada.
Im not going to drive it in the snow, but it will get driven until first snowfall then stored. 10w30 vs 20w50 whats the diff? i heard synthetic in my car would cause all kinds of leaks
1989 944 2.7L n/a |
http://www.weatherbase.com/weather/weather.php3?s=072617&refer= 10-40 would be my choice. Again, read what others think on the link in my post above. The idea is to protect your crank and rod bearings-#2 especially, upon startup and severe driving. GL John_AZ |
Parrothead member
Castrol GTX or Valvoline 20-50 in the warmer months. 10-40 in the cold weather
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
One apex at a time
Pull the coil wire, after you change the oil and belts, when you try to fire it up.
the funny part about that, I took apart the timing belt cover to start a belt change but alas it was in perfect condition. bizarre, I know.
1989 944 2.7L n/a |
Changed to 20W - 50 dino this summer. Motor runs smoother and oil pressure is now 4,5 bar under load and 2 bar in idle with warm engine... a raise of more than 0,5 bar compared to a unknown oil from PO.
_________________________________ Lapponia 1984 944 na |
Timing belt a DIY job if you are mechanically handy but have never done it on a 944 engine?
