Intermittent wipers
My windshield wipers do not turn off in the off position on the column lever, but go into intermittent mode. All three of the other positions work properly, high, low and intermittent. The washer function is ok too.Is this likely a problem with the column switch or in the wiper motor itself? 1983 944. |
Probably the switch.
Good luck, George Beuselinck |
I'm having the same problem after I let the car sit during my long clutch job. So will corrosion in the switch contacts cause this problem? I'd like to know if any of you guys have found my symptons to be the relay before I tear into the column. Relays are way easier to change and I'm getting tired of using RainX.
70 911T 71 914 89 BMW R100GS |
Redline Racer
The quick fix to get basic wiper functionality back is to pull the relay. They won't return on their own so you have to manually "park" them...I've gotten so good at that it's practically automatic by now. I'd be interested in what the problem is as well. I just haven't gotten around to deciphering the wiring configuration or getting ahold of a known good relay yet. The relay is a bit complicated with a few other discrete components that there's no telling how to easily tell if it's bad or if it's just the steering collumn switch.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Might check out the PC Board in the relay, ...has ordinary 80's style components. Just replace them all, ...diodes, transistors, caps, ...Fry's, Radio Shack.
83' 944 NA Red w/Black Original Owner |
Garage Helper
It's almost always the column switch. It's a 50/50 chance one can remove the column switch and clean all contacts to get it working properly. I have found though over time it's easier just to replace the switch assembly with a known good used unit.
Of course it's easier to replace the relay, and I always have a spare relay to check it out, but 90% of the time it always leads back to the column switch assembly.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
Overseas
You know that the switch positions are as follows, right?
4 (most top): fast 3: slow 2: off (!!!) 1 (lowest): intermittent
Tomiki 924S (1986) |
Coming up on your left...
^I was gonna say...lots of people do get caught by that.
1986 Porsche 944 Turbo "S" clone ![]() 1998 Honda Accord ![]() Siena College '08 Manager, Mavis Discount Tire
where is the relay located?
Pete Porsche, there is no substitute! 911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv |
I bought a relay and swapped it. it worked for a little while correctly. My next step (before my clutch blew) was to attack the grounding curcuit.
Now...I'm wondering if one of these relays did fix it since I didn't know that all the down wasn't off.
1983 Porshe 944 N/A 5sp Guards Red |
