Question Switching ECU'S
Would an 86 NA ECU work on an early car (84).
Old 05-04-2010, 12:33 PM
Yes, but I believe that you would have to put in a newer AFM in as well.
Old 05-04-2010, 02:55 PM
yup. AFM and the DME (what the ECU is called on these cars) need to be same generation.
Old 05-04-2010, 03:09 PM
thekidd's Avatar
Send a message via AIM to thekidd
have an 86 ECU and AFM in my car now. Its good to do if you track the car because yuo can chip it easier with better chips. It also stops the "idle stumble" on the early modles where you rev the car and then drops to 600 RPMs, latemadels dont do that.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 05-04-2010, 04:36 PM
Any other benefits to adding a late ECU to an early car besides chipping and idle stumble?
Old 05-05-2010, 08:51 AM
removes weight from your wallet so you go faster?
Old 05-05-2010, 10:34 AM
smokin_944's Avatar
lol...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 05-05-2010, 03:59 PM
