Would an 86 NA ECU work on an early car (84).
Yes, but I believe that you would have to put in a newer AFM in as well.
yup. AFM and the DME (what the ECU is called on these cars) need to be same generation.
have an 86 ECU and AFM in my car now. Its good to do if you track the car because yuo can chip it easier with better chips. It also stops the "idle stumble" on the early modles where you rev the car and then drops to 600 RPMs, latemadels dont do that.
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
Any other benefits to adding a late ECU to an early car besides chipping and idle stumble?
removes weight from your wallet so you go faster?
lol...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers |
