"Ferdinand's finest"
lowenschlo's Avatar
timing belt help
Im buying a timing belt kit from pelican parts. I have a 1985 early 944 na. im replacing the water pump as well, to re factory updated pump. Do I need the kit with the 32mm pump roller or 46mm??
Thanks!!
Drew
"The fastest lap time you will ever record, will always be done behind someone else" - Yours truly
Old 06-22-2011, 06:33 AM
smokin_944's Avatar
If you are buying the updated pump I believe you will require the 46mm. The new WP will come with a block off piece and a rail (that is the update).
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 06-22-2011, 07:22 AM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
+1^ Next paragraph...
You can get an old style Water Pump (Brand New) and use the old style 32mm belt roller, but it is much better to up-grade to the new style water pump w/Belt Guard and use the 46mm roller with it.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 06-22-2011, 07:49 AM
ernie9944's Avatar
Thanks!!
Drew
You will also have to modify your rear timing belt cover,John_AZ has the template for cutting the hole.Just shoot him a pm or he migth post it here explaining how to go about it.
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 06-22-2011, 11:15 AM
