XD
B944's Avatar
Question Im back and need help!
Hey guys, you probably don't remember me cuz i haven't been on in a while. Anyway, my 944 was running perfect last summer, then during the winter it kinda sat. Now there is no power going to the fuel pump. It's got a new relay and pump, but now if I try to start it, there is only less than 1 volt going to the pump. If i bypass the system the pump works but the regular system won't give it enough power. Any suggestions?
"Kids, don't use Formula 1 race cars to chase hedgehogs"- Sonic the Hedgehog
1985.5 944 N/A
Old 07-07-2011, 09:09 PM
XD
B944's Avatar
Anybody have suggestions?
Old 07-12-2011, 09:45 AM
Proprietoristicly Refined
John_AZ's Avatar
B944
Just a couple of ideas>
Here is the Fuel related test per Clarks:
Troubleshooting Fuel Supply Problems
It could be a cracked ignition switch or the switch wiring--rear contacts.
http://www.clarks-garage.com/pdf-manual/elect-17.pdf
Ignition Switch Replacement
When you turn the key, you should be able to hear the hum of the fuel pump.
You said you have already replaced the DME/fuel pump relay for a new one. Did you try the jumper per Clarks?
DME Relay Information and Testing
Clean all grounds by the battery and the engine block.
Finally, when you crank the engine, does your tach needle bounce 1/16 of an inch??
GL
John
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 07-12-2011, 11:02 AM
