Tcrate's Avatar
Engine Pull
Looking for some input here. I am looking at buying a 951 which has an oil leak. I will probably have to pull the motor. Having never pulled one of these can anyone give me an estimate of the hours required to pull a 951 motor. Seeing as it will be my first time I will assume the worst as I am aware the second and third time around it usually goes quicker. I read the write up on clarks My guess would be maybe 8 hours but not really sure. Any input from someone who has done this would be greatly appreciated. Thanks. Thom
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
1973 Mustang Mach 1 351C
Old 12-02-2011, 09:04 AM
It only takes a few hours if all of the bolts come off. Soak the torque tube to bellousing bolts and any bolts you can get to with PB blaster/liquid wrench/WD 40 or whatever you like to use the night before.
Old 12-02-2011, 09:45 AM
Toofah King Bad
Rasta Monsta's Avatar
If you can manage the eight hour estimate, I think you will have done damm well.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-02-2011, 11:53 AM
8 hours is a solid estimate. You are correct it is much faster after your second or third (or 12th...) time. I was able to switch engines between two 944 racecars in a weekend, starting about 3PM on the first day til dark, and maybe 10am and done before dark the second day with a 944-savvy helper. Probably 15 hours total.
Old 12-02-2011, 01:03 PM
Tcrate's Avatar
Thanks for the input. Will see how it goes.
Tom
1987 911 Targa
1987 944 Turbo
1976 911S
Old 12-02-2011, 02:41 PM
first u have to decide: transaxle pull or not , out the top or out the bottom. heh
Old 12-02-2011, 03:25 PM
Custom User Title
mikepellegrini's Avatar
Before you go spending all those hours/days pulling the engine, you might better spend a few minutes and try to localize where the oil is coming from.
Most of the places oil drips from on 944's are accessible without any major pulling efforts.
Might end up saving yourself a whole lot of time and effort.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 12-02-2011, 05:43 PM
Pete R's Avatar
+1
I can't think of any seal that can't be done in the car. If your going to do ALL of them it may be easier out. I'll let you know though, I have to do my lower balance shaft this winter. Looks like a PIA just looking at it/
1979 928 85 Euro 2v motor,S4 Brakes and suspension, 1988 951 street legal track car(sold)
Neon SRT4 track car
Old 12-02-2011, 06:15 PM
if you DROP it...rebuild it. oh and don't forget the new clutch!
1988 944 turbo
Old 12-02-2011, 09:48 PM
+1. While not a horrible job, pulling the engine on a turbo car really isn't all that fun either. If you don't intend to mess with the suspension, you can pull it from the top and save some time.
Old 12-04-2011, 11:54 AM
