924 alternator not charging
I was reading the ( '83 won't start ) post, and wondering if my ignition switch would cause my alternator not to charge?
It's a track car, so it does not get regular runs outside of 30 minutes sessions.
A while back my battery dash light flickered on. My volt guage that said it was returning only 12 volts. hmm..
tested alternator - it's good. Checked and cleaned all grounds - solid.
now dash light is solidly on, and volts are about 10.5 - and drops as the battery goes dead.
Everything works and Car starts when battery has good charge.
Wondering if a simple ignition switch change would fix?
thanks...
Old 12-30-2011, 10:53 AM
Toofah King Bad
Rasta Monsta's Avatar
More likely wiring to the alt.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 12-30-2011, 11:44 AM
yarfk
kfray's Avatar
The ignition switch pin 15 supplies 12 vdc to one connection of the Alternator lamp, the other connection of the alternator lamp is connected to the +D terminal of the alternator (the small wire on the Alternator) this is the field excitation voltage. This wire could be bad.
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 12-30-2011, 12:43 PM
924RACR's Avatar
924 or 924S?
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 12-31-2011, 07:20 AM
Old 01-02-2012, 09:53 AM
