924 alternator not charging
I was reading the ( '83 won't start ) post, and wondering if my ignition switch would cause my alternator not to charge?
It's a track car, so it does not get regular runs outside of 30 minutes sessions. A while back my battery dash light flickered on. My volt guage that said it was returning only 12 volts. hmm.. tested alternator - it's good. Checked and cleaned all grounds - solid. now dash light is solidly on, and volts are about 10.5 - and drops as the battery goes dead. Everything works and Car starts when battery has good charge. Wondering if a simple ignition switch change would fix? thanks... |
Toofah King Bad
More likely wiring to the alt.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
yarfk
The ignition switch pin 15 supplies 12 vdc to one connection of the Alternator lamp, the other connection of the alternator lamp is connected to the +D terminal of the alternator (the small wire on the Alternator) this is the field excitation voltage. This wire could be bad.
------Keith------kfray------yarfk------- 87 944 NA stock 116k 06 Honda Ridgeline 83k 10 Vibe 2.4 AWD (Wife's) Retired My week consist of Saturdays and Sundays
924 or 924S?
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
