What else to check?
I am going to replace the clutch in my '83. The timing belt was done about a year ago with the water pump. The car has near 90K and I have gone thru all the paper work from PO and havent seen anything major, belts, oil...ect. I was planning on doing the following while under the car.
1. replace trans fluid 2. replace RMS 3. re-pack CV,s 4. re-pack wheel bearings F&R 5. paint calipers 6. brake job 7. SS brake lines 8. short shift kit 9. filters and oil I would like to shorten the shifter but still keep factory knob, just to make it easier to get to radio. Still debating struts and shocks. It is a week-end toy and stays pampered in the garage. I would like to get it to up to use as a DD, no plans on DE's or racing, occasionally a little sprited on the interstate. SO.......what did I miss or forget about? |
If your going to repack the bearings you might as well just replace them. Do it the same time you do brakes since you have to take the front off to do the front rotors.
I would add a full tune up...plugs, wires, distributor, rotor unless it has been done recently. |
Garage Helper
Check all vacuum lines for looks and leaks - replace as necessary...
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
good time for speed and ref sensors if they are over 10 years old or brittle \ cracked connectors
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
Custom User Title
This is a great time to cut-out the sensor holes on your bellhousing. It makes it a whole lot easier to get off for future jobs.
83 944 NA - Black on black 86 951 - Red - SOLD 7/21 16 Ford Expedition He who hesitates is lost. |
Toofah King Bad
Hey Pellegrini, a while back I bought that same Craftsman tool kit. . .for my wife.
:P
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Custom User Title
Seriously? Man, that's some wife you got!
Also a good time to enroll in anger management classes. And purchase some stock in GOJO cleaners.
Good times ahead
1988 944 turbo |
I don't know if this was in the plan for the clutch job. BUT while you have the bell housing off, new pressure plate, new clutch disc, new RMS (already mentioned), new throw out bearing. and clutch fork bearings. While you have the flywheel off, have it resurfaced. Make sure to clean off the clutch fork and inspect for cracks. I had to replace mine because it was cracked
Use moly lube in the bearings and pivot points. You'll need it for the CVs anyway.When you drop the transaxle, I found it easier to unbolt the carrier from the frame, others will disagree.
Bruce P. 2011 Cayman Base, LSD, Sport Chrono. 1988 951 totaled and missed ![]() "You're the best I ever had" --JJ Cale |
