New heater valve tonight with both hoses then a 70 mile run to Cherokee and back. .
Old 06-05-2015, 08:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2901 (permalink)
The fail point
You can see where the glue is coming loose. It peed a bit on the floor one night and the pressure test showed a drip down the heat shield under the valve.
Old 06-05-2015, 09:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2902 (permalink)
And the next pressure test...pumped with 8psi of air and squirting everything down either some diluted soap.
Old 06-05-2015, 09:47 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2903 (permalink)
mhariush's Avatar
Originally Posted by dp951 View Post
Shirt is looking good dp951! Don't miss the new ones, and the coverall
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 06-05-2015, 11:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2904 (permalink)
Finally got my S back on the road after a long time laid up for new belts, rollers, WP, front oil seals, coolant hoses, manual steering swap, and new front swaybar. Feels great, except I know she's gonna be laid up again before too long for a front suspension refresh.
Can't wait until I'm finally caught up on all the PO's deferred maintenance and I can drive her more often than wrench on her!
Old 06-06-2015, 05:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2905 (permalink)
I finally pulled my instrument cluster and got some functioning dash lights!
All without even breaking a tab. I broke a bunch of plastic doing that on my Volvo, and that is 15 years newer.
I want to wire up some foot well leds to the door open switch. For some reason, the overhead light isn't activated by door opening, just the rocker switch.
Old 06-06-2015, 05:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2906 (permalink)
Repainted my wheels after having my local independent mechanic pull the 13 year old tires off. I will have the new tires put on on Monday after waxing the wheels.
Before.
After.
1987 944 Summer
2006 E90 Winter
Old 06-06-2015, 05:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2907 (permalink)
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
After being garaged for six years, I started the long process of getting my 83 back in running order. She'll be a stripped down street/track car when I'm finished.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 06-06-2015, 06:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2908 (permalink)
Tom, did you use VHT or Wurth paint...or some other brand?
Old 06-06-2015, 08:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2909 (permalink)
Chunkerz's Avatar
Today I began the daunting task of putting my dash in and the rest of my interior back together. I've been putting it off for weeks, but I felt bad just letting my car sit without any love so I decided to finally tackle it tonight. It really wasn't as bad as I thought it was going to be.
Old 06-06-2015, 09:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2910 (permalink)
mhariush's Avatar
Got a smog test, passed on the numbers, but the technician was too good at his job so he tested the EVAP system that no one has tested before. Found a leak. Sigh. Going to try a different place on Monday and then chase down the leak eventually.
Also, my headlight motor stopped working and became super hot to the touch.
Old 06-06-2015, 11:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2911 (permalink)
Just fined tuned my EBC - it took me 20 minutes, including reading the manual. Now I have it set as I planned initially. I have around 13.5 - 14 PSI up to 4500 rpm, then is starts a linear drop to around 11 PSI around at 6000 rpm. Still have the original head gasket and the engine was never "opened" in its 27 years and 140 miles, thus don't want to put much stress on it until I change the bearings, change head gasket and do some other things if required while there later next winter.
Would be interesting to see how much HP does it have now. The engine is original, it has 3 inch cat-less exhaust (including down pipe), Tial WG, EBC and A-Tune. Might bring it to dine later this summer. I think it might have some additional 25 - 30 HP in the whole rpm range.
Old 06-07-2015, 03:36 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2912 (permalink)
I used Wurth. I made a quick booth in my garage since I expected the flake to go everywhere.
Only issue was that a lot of the flake settles back on the painted rims leaving a rougher than expected finish. They look fine though so I will just polish them a bit with some wheel wax.
I was careful to move my wife's limited edition black on black with even more black Evoque way out of the way!
1987 944 Summer
2006 E90 Winter
Old 06-07-2015, 06:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2913 (permalink)
Converted to a manual sunroof. Replaced the cookie cutters with 16x7/8 Ronal R9's! Too bad the tires on them are flat spotted from sitting too long.
Old 06-07-2015, 12:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2914 (permalink)
p-talk's Avatar
those are great-looking wheels 'motorwinder'. They have a very 80s aesthetic to them that matches the early cars nicely.
1984 Porsche 944 - Mathilda the needy
2014 Audi Allroad - daily driver
Old 06-07-2015, 12:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2915 (permalink)
I wasn't too sure how I'd like the red centers, but now that I look at them it's grown on me. I guess I'm a little bit of a pursit, but I like keeping a car period correct as I can. At least when it comes to appearances.
Old 06-07-2015, 06:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2916 (permalink)
AFM #725
Gawernator's Avatar
Originally Posted by mhariush View Post
You're selling your car Gaw? Getting a new one or getting out of them?
I started my 87 S, ran if for a while. Has been sitting in the garage for over a year and a half. Redid the engine harness and plugged some vacuum leaks. Looks like a ground issue was causing the overheating I had for a while.
Let's hope it passes smog!
And the other day I took a pic of my 996 milage, didn't even notice the time until after.
Well, I still have my 986 that I like a lot. I don't have the time or patience for my 944 anymore or garage space... it has been replaced by my Kawasaki Ninja lol...
I haven't DD'd my 944 for over 1.5 years.
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 06-08-2015, 03:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2917 (permalink)
Had new tires installed and put them and the re sprayed rims back on.
1987 944 Summer
2006 E90 Winter
Old 06-08-2015, 04:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2918 (permalink)
I was not 100% happy with the finish so I hit the rims with a wool polishing pad on my buffer. Wow what a difference, smoothed and evened out the coat a huge amount. Much happier now. I will take a look at it in the daylight and see if it needs nor polishing/cutting.
1987 944 Summer
2006 E90 Winter
Old 06-08-2015, 05:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2919 (permalink)
Are you going to clear the wheels? I was curious if the wurth was closer to matching the existing paint on the center caps.
Old 06-08-2015, 06:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #2920 (permalink)
