Radio Relay
Has anybody actually seen a failure with the radio relay on early 944s? Is it common?
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
if you're talking about the relay that turns on the radio when you insert the key then yes i've had two fail on the 84 - of course that said i did replace them with old used ones so it could be they were at the end of their life anyway
84 928 S - SOLD 2012 Cayenne S |
Just thinking out loud
Never had the radio relay fail, but I have had a couple of ignition switches that wouldn't allow the radio to turn on when the key was inserted.
83 944 91 FJ80 84 Ram Charger (now gone) |
That is sort of what I'm wondering. WHat is the fix?
I replaced the electrical portion of the ignition switch. Actually the original became cracked and the radio only worked when the key was turned just right. I was constantly fiddling with it while the car was running to keep the radio on. After I replaced it, it worked normally again until that switch took a complete dump and wouldn't even start the car. Replaced it, all is normal.
