j911brick's Avatar
Radio Relay
Has anybody actually seen a failure with the radio relay on early 944s? Is it common?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 04-22-2013, 11:00 PM
honerboys's Avatar
if you're talking about the relay that turns on the radio when you insert the key then yes i've had two fail on the 84 - of course that said i did replace them with old used ones so it could be they were at the end of their life anyway
84 928 S - SOLD
2012 Cayenne S
Old 04-23-2013, 09:57 AM
Just thinking out loud
mattdavis11's Avatar
Never had the radio relay fail, but I have had a couple of ignition switches that wouldn't allow the radio to turn on when the key was inserted.
91 FJ80
84 Ram Charger (now gone)
Old 04-23-2013, 10:01 AM
j911brick's Avatar
That is sort of what I'm wondering. WHat is the fix?
james
Old 04-23-2013, 06:51 PM
I replaced the electrical portion of the ignition switch. Actually the original became cracked and the radio only worked when the key was turned just right. I was constantly fiddling with it while the car was running to keep the radio on. After I replaced it, it worked normally again until that switch took a complete dump and wouldn't even start the car. Replaced it, all is normal.
91 FJ80
Old 04-24-2013, 05:53 AM
j911brick's Avatar
My radio hasn't worked in a couple years. Didn't need it so I didn't give it a thought. Now the radio sometimes comes on when the key is removed. Maybe I'll try the switch first.
james
Old 04-24-2013, 06:14 AM
