Misc trivia - should be easy
Some trivia I have kicking around like usual:
1. Rebuilding CV joint with the GKN kit - which face faces where? I assume the thin channel at the edge of the joint is where the boot large rim mates, and therefore on the outside edge. Also which way does the concave washer face - I assume opening toward the joint.
2. What fasteners attach the heat shield to the late NA? Especially to the speed nuts. I made a mess of mine, and the piece isn't in the PET.
3. Which way do the exhaust hanger pieces - the one between the cat and muffler - face?
Old 11-15-2015, 02:27 PM
curtisr
curtisr's Avatar
To answer your first question I'd start with Van's excellent two-part video https://www.youtube.com/watch?v=LsytyVzokBg or irinna's video which can also be found on youtube at http:/https://www.youtube.com/watch?v=DY1VECxKCHs
This is not a difficult job really. One tip I'd offer is use of the top part of a jack stand as a wedge under the tire when removing the 12 point bolts. There are six bolts per joint and naturally the wheel will want to rotate if you don't secure it. This will save you getting out from under the car each time you need to spin the tire.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 11-15-2015, 07:40 PM
[CV joints] OK good call, rewatched VanSvenson, I was right.
How about non-hardening sealer between the boot flange and the joint?
Old 11-16-2015, 07:21 AM
Sealer is not necessary as long as the mating surfaces are good and clean.
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 11-16-2015, 02:09 PM
Did some homework - for the heat shield - Looks like 2X M5 and 2X M6 fender washers, 2X M6 hex bolts (of some length/pitch), 2X M5 screws of some type - sheet metal? Thinking about some red Loctite.
Old 11-17-2015, 12:22 PM
