1988 944 2.5L 8-v NA 301k
My '88 with R134 runs the coolant temp about 35F hotter with a/c activated. (205F on a 95F day)
Same day, same temp but a/c off sees 170F during same conditions. Hmmmm.... Vent temps are about 30F less than ambient air temps..
'88 8v n/a 301k with 41k on current TBelt M454 M533 M650 M425 M418 ![]() New Feb'13 Bridgestone Grid 019.. awesome. Paid just $1,700 running & inspected. Big RUSH Fan! Lic Plate = LIFESON |
Mine hasn't worked for the 5 years I've had my 90 S2. I've never even looked at it. I just try to drive at night down here in Georgia.
1990 S2 Coupe |
It works and is nice and cold when there's freon. A day later after the freon has leaked out of the compressor it's useless. If I don't sell the car I'll fix it.
It could also be an inefficient compressor (leaking valves), but overcharging the system is probably more common. |
How much am I looking at for r134 conversion? Freon illegal where I live, not sold anywhere.
Might leave it as is. My back is always soaked when I get to work though, ah well. The leather seats don't help I suppose. |
I replaced the compressor 2 years ago and refilled with R12. My first time working on ac but I had a friend with most of the tools. Has been working great since. Only issue is that it massively speeded up the dash cracks!
1987 944 Summer 2006 E90 Winter |
Patrick
Alaxk,
134a conversion isn't very expensive. I had a local ac guy charge me about $60.00 labor. I think it's simply a couple of Schrader valve replacements (low side with blue cap and ?), a couple/few new o-rings, new drier, pressure valve, and a complete evac/refill of new refrigerant. You can get all the parts here on PP.
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
I have the compressor and it's bracket and the condenser that I removed two years ago. Free to anyone. Just pick up or pay the shipping.
Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
Have 944, will restore
I have 3 944's and the a/c does not work on any of them, lol
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
A/c
I had mine converted from R12 to R134A just recently. It works great and was worth the money. It's a lot more enjoyable to drive it on hot days. The A/C now works better in my 86 944 than my 2005 Ford.
R-12 uses a mineral oil while R-134a uses an alkaline benzine oil. You have to have the oil flushed out completely, evacuated and replaced. They usually would replace whatever o-rings possible because they will be saturated with the old oil, and mixing the oils turns it to an unpleasant sludge. That would be the bare minimum, WYIT approach would be to replace the metering device as well as rebuilding the compressor but that might not be necessary.
Does anyone know how the fan speed is controlled? Are the resistors located in the switch panel (meaning you'd have to replace the switch panel) or are they at the motor? My motor only works on 4... |
the fan resistors in my '90 are located in the top of the Star Wars lookin air blower housing under the hood, just to front of the fire wall.
I think the good Dr Ferd inserted them in the housing & air flow to cool them a bit . two screws Last edited by gtgt__bangbang; 07-05-2014 at 11:30 PM.. |
Thanks brother, I will pop them out for a look. I haven't found a write up for that yet, seems like it is a common problem. Maybe I should do one...
Just thinking out loud
When I replaced the shaft seal, I added 2oz of PAG 46, sucked it down and filled it up with R-134a. Been blowing high twenties for about 10 years. OE all the way except the seal, and a low side adapter.
83 944 91 FJ80 84 Ram Charger (now gone) Last edited by mattdavis11; 07-05-2014 at 12:55 PM.. |
I agree. Mineral oil in non-miscible with R134 so it just sits in the system at low points doing no harm. I added ester oil when I refilled with R12. This is compatible with both so I can just top up with R134. Garages won't do this because of their machines but I don't believe there is any chemical reason not to mix them.
JJR512 - that 200 RPM drop is normal when running your AC compared to it being off...
- 1985/2 944 Alpine White, Fuchs Musik Stadt chapter of PCA |
I have a/c in my 89, 88, 85, and I am about to get my 87 n/a charged.I just put a good compressor on it.
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car) |
brad no its a few screws. lets do a deep dive to flush the evaper.
actually thats done, just waiting ot leak check to wrap it up. would NOT want to tear out the StarWars stack again, its sticky. |
The series resistor in my car is beyond saving... The bimetallic safeties are completely crumbled.
