1988 944 2.5L 8-v NA 301k
VirginiaF1's Avatar
My '88 with R134 runs the coolant temp about 35F hotter with a/c activated. (205F on a 95F day)
Same day, same temp but a/c off sees 170F during same conditions.
Hmmmm....
Vent temps are about 30F less than ambient air temps..
'88 8v n/a 301k with 41k on current TBelt
M454 M533 M650 M425 M418
New Feb'13 Bridgestone Grid 019.. awesome.
Paid just $1,700 running & inspected.
Big RUSH Fan! Lic Plate = LIFESON
Old 07-03-2014, 07:07 PM
Phantoms's Avatar
Mine hasn't worked for the 5 years I've had my 90 S2. I've never even looked at it. I just try to drive at night down here in Georgia.
1990 S2 Coupe
Old 07-04-2014, 12:30 AM
veleno's Avatar
It works and is nice and cold when there's freon. A day later after the freon has leaked out of the compressor it's useless. If I don't sell the car I'll fix it.
Old 07-04-2014, 04:33 AM
Bradical's Avatar
Hmmmm....
Sounds overcharged. This would cause the high-side pressure to run elevated, thus raising your condensing temperature and making the air entering you radiator hotter than ambient. It would also elevate your suction pressure, which would raise the temperature of the evaporator and cause poor cooling effect.
It could also be an inefficient compressor (leaking valves), but overcharging the system is probably more common.
Old 07-04-2014, 04:53 AM
How much am I looking at for r134 conversion? Freon illegal where I live, not sold anywhere.
Might leave it as is. My back is always soaked when I get to work though, ah well. The leather seats don't help I suppose.
Old 07-04-2014, 07:39 AM
I replaced the compressor 2 years ago and refilled with R12. My first time working on ac but I had a friend with most of the tools. Has been working great since. Only issue is that it massively speeded up the dash cracks!
1987 944 Summer
2006 E90 Winter
Old 07-04-2014, 07:46 AM
Patrick
pfarah's Avatar
Alaxk,
134a conversion isn't very expensive. I had a local ac guy charge me about $60.00 labor. I think it's simply a couple of Schrader valve replacements (low side with blue cap and ?), a couple/few new o-rings, new drier, pressure valve, and a complete evac/refill of new refrigerant. You can get all the parts here on PP.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-04-2014, 11:03 AM
I have the compressor and it's bracket and the condenser that I removed two years ago. Free to anyone. Just pick up or pay the shipping.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 07-04-2014, 11:19 AM
VirginiaF1's Avatar
Porsche Crest
Top notch.. thanks mate!
Old 07-04-2014, 12:26 PM
Have 944, will restore
mazdaverx7's Avatar
I have 3 944's and the a/c does not work on any of them, lol
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 07-04-2014, 02:31 PM
Ericv's Avatar
A/c
I had mine converted from R12 to R134A just recently. It works great and was worth the money. It's a lot more enjoyable to drive it on hot days. The A/C now works better in my 86 944 than my 2005 Ford.
Old 07-04-2014, 09:21 PM
Bradical's Avatar
R-12 uses a mineral oil while R-134a uses an alkaline benzine oil. You have to have the oil flushed out completely, evacuated and replaced. They usually would replace whatever o-rings possible because they will be saturated with the old oil, and mixing the oils turns it to an unpleasant sludge. That would be the bare minimum, WYIT approach would be to replace the metering device as well as rebuilding the compressor but that might not be necessary.
Does anyone know how the fan speed is controlled? Are the resistors located in the switch panel (meaning you'd have to replace the switch panel) or are they at the motor? My motor only works on 4...
Old 07-05-2014, 12:02 PM
the fan resistors in my '90 are located in the top of the Star Wars lookin air blower housing under the hood, just to front of the fire wall.
I think the good Dr Ferd inserted them in the housing & air flow to cool them a bit .
two screws
Old 07-05-2014, 12:27 PM
Bradical's Avatar
Originally Posted by gtgt__bangbang View Post
the fan resistors in my '90 are located in the top of air blower housing under the hood, just to front of the fire wall.
two screws
Thanks brother, I will pop them out for a look. I haven't found a write up for that yet, seems like it is a common problem. Maybe I should do one...
Old 07-05-2014, 12:45 PM
Just thinking out loud
mattdavis11's Avatar
134a needs PAG, Polyalkylene Glycol, and you don't have to flush out the mineral oil if you don't want to. Nor do you have to change the drier.
When I replaced the shaft seal, I added 2oz of PAG 46, sucked it down and filled it up with R-134a. Been blowing high twenties for about 10 years. OE all the way except the seal, and a low side adapter.
91 FJ80
84 Ram Charger (now gone)
Old 07-05-2014, 12:53 PM
I agree. Mineral oil in non-miscible with R134 so it just sits in the system at low points doing no harm. I added ester oil when I refilled with R12. This is compatible with both so I can just top up with R134. Garages won't do this because of their machines but I don't believe there is any chemical reason not to mix them.
1987 944 Summer
2006 E90 Winter
Old 07-05-2014, 03:05 PM
gmorken's Avatar
Originally Posted by JJR512 View Post
I have an '86 NA as well. Mine works, but it's very weak. It also lowers the idle rpm about 200, not sure if that's normal or a symptom of being low on Freon or something else.
JJR512 - that 200 RPM drop is normal when running your AC compared to it being off...
1985/2 944 Alpine White, Fuchs
Musik Stadt chapter of PCA
Old 07-05-2014, 06:43 PM
PorscheChef's Avatar
I have a/c in my 89, 88, 85, and I am about to get my 87 n/a charged.I just put a good compressor on it.
'87 951 Nile Green, '86 951 Black, '86 951 Sapphire Metallic, '87 944 Nautit Blue, '84 944 Black (sunroof delete) "Track Beast!," '87 944 Black (LSD, Konis) (wife's track car)
Old 07-05-2014, 07:57 PM
brad no its a few screws. lets do a deep dive to flush the evaper.
actually thats done, just waiting ot leak check to wrap it up.
would NOT want to tear out the StarWars stack again, its sticky.
Old 07-05-2014, 11:33 PM
Bradical's Avatar
The series resistor in my car is beyond saving... The bimetallic safeties are completely crumbled.
Old 07-06-2014, 08:00 AM
