Anybody have working a/c?
Mine has never worked. 86 944.
Worth it to fix?
Most of you running with or without?
Old 07-03-2014, 01:40 AM
Bradical's Avatar
I am tackling mine this weekend. I live in Florida, so yeah, it's totally worth it!
Mine just seems to be low on charge, though.
Old 07-03-2014, 04:33 AM
kuehl's Avatar
It always comes down to driving time.
You will have more enjoyable days driving the car when the ac works.
Old 07-03-2014, 04:44 AM
1990 944S2
Send a message via Skype™ to ChrisRL
In Los Angeles? Heck yeah.
Had a Lotus Esprit Series 1, black on black, awhile ago and it had a decent fan but no A/C.
This time around in my 90 S2, no way without one.
84 944 gold sold
90 944S2 black current DD
89 735il white fixing
89 GL1500 white restoring, 01 955i S3 black current DD
01 955i Sprint brg customizing, 89 955i Daytona gold restoring
Old 07-03-2014, 06:39 AM
Mine doesn't work, but I haven't had a need to look into it......yet. Ive been preferring to just remove the sunroof. But then again, Im about to have my first summer with the car being drivable, so maybe I'll change my mind this summer .
Silver '83 944 - RIP 12/12/2014
Old 07-03-2014, 08:37 AM
Volhv's Avatar
I removed mine. Did the delete, and it cleaned things up a fair bit. It wasn't operational, and I did not want to waste my time figuring it out. Where I live, the highest it ever really gets is 88, and I think the record high, 5 years ago was 100. If I lived in a different climate, I would have kept it.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-03-2014, 08:52 AM
Mine works and does a nice job considering the Phoenix heat.
85 Carrera Coupe
Old 07-03-2014, 08:58 AM
9FF 9FF is offline
9FF's Avatar
It's out of my track cars and working on my street cars. I live in FL so I would get little use of a street car without AC. Cool suits in the track cars really help me get some year round track time.
Basically fix it if you need to use your car on hot days otherwise it'gets really uncomfortable.
Old 07-03-2014, 09:06 AM
White and Nerdy
Tervuren's Avatar
In an early model 944, even when working properly, it *barely* keeps up with the 105F temps out here in summer. Late model '44, keeps up just fine. For an early car, might be better to remove entirely, be a 'lil more sporty, for a late car, go for it, be comfortable.
Just beware - when one system has failed, the rest may shortly follow after, so don't expect cheap/easy.
Shadilay.
Old 07-03-2014, 09:16 AM
jwmc1's Avatar
Mine works...use it rarely though, I like the drive without it, but on those 85+ days, it is nice to have the option
John
one of gods prototypes
bell's Avatar
87 924s......
My a/c is so cold it could freeze an Eskimo. ....
Old 07-03-2014, 09:29 AM
mhariush's Avatar
I got mine fixed with a new compressor on ebay. A definite yes here in Los Angeles.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 07-03-2014, 10:17 AM
Mine works pretty decently after 5 minutes of being run, but does not provide cool air instantly. I think it needs a can of refridgerant to get it back up to snuff
Old 07-03-2014, 10:21 AM
Mine works well in my early 944.
Might need a little more charge though...I installed a Pelican rebuilt compressor recently.
makes the car much nicer to drive.
Old 07-03-2014, 10:45 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
I'm in Florida where it's 92 degrees every day during the summer. A year ago when my A/C started to falter I went to a local air conditioning shop and they converted it over to R134. It has worked flawlessly since. An operational note: Because the system can only recover a certain ratio of outside temp to inside cool, it's recommended that when you feel the inside temp getting a little cooler, go to the recirculating mode on your A/C controller. That way, the inlet temp to outlet temp baseline is lowered and the car gets cooler. It also helps prevent the condenser from icing up. I have a dark color car which makes it a bit harder for the A/C to overcome but it does work using this method.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 07-03-2014, 12:17 PM
RM512's Avatar
Had to replace the condenser when i bought the car in '04. Still had a 30# jug of R-12. Works great!
Old 07-03-2014, 12:22 PM
I have an '86 NA as well. Mine works, but it's very weak. It also lowers the idle rpm about 200, not sure if that's normal or a symptom of being low on Freon or something else.
Old 07-03-2014, 12:47 PM
Patrick
pfarah's Avatar
Mine worked fine until I replaced the original 30 tear old compressor (which leaked oil all over the place) just the other day. I had the local AC shop evac/fill; they said it blew ice cold. I picked it up later that day and absolutely nothing. It's this weekend's project... Hopefully something simple.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 07-03-2014, 02:27 PM
Just thinking out loud
mattdavis11's Avatar
Yep, works better than nearly all cars on the road today. R134. Black, no tint and the 100's are coming.
91 FJ80
84 Ram Charger (now gone)
Old 07-03-2014, 03:44 PM
'85 944 here. Had a Pelican rebuilt compressor installed along with the a/c switch. Had to jump the switch to get it to run to charge it. Would not kick on as it should. Back in the shop...can't do much anymore myself...health matters/copd hence I do need AC!
Old 07-03-2014, 03:45 PM
