Crippler's Avatar
Unhappy Why not to skimp on gaskets
This summer when I replaced the cam tower gasket I thought I would save some bucks and just buy an aftermarket one. Why not just he same thing only cheaper, right? WRONG!
After about a month of driving it let go and oil ran all over the exhast manifold. So it looks like I have a big mess to clean up and a bunch of time needed to tear it apart again. I will be getting a O.E. gasket from the porsche dealer this time though.
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 09-25-2002, 09:34 PM
SoCal Driver's Avatar
You may just find that the gasket the dealer sells is made by the same company as the aftermarket one.
Paying double to triple to a dealer doesn't make it better.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-26-2002, 02:05 PM
Agree with Hugh, this sounds more like incorrect assembly than anything else....You did use a torque wrench didn't you?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-26-2002, 02:52 PM
As this is a high oil pressure galley (between the cam housing and head) it's critical to prepare the surfaces and use the proper sealant as well as the correct torquing values and sequence.
I've had similar happen to me and found just the trace of the old gasket were the leak occurred.
If this is just the cover then the same but not as critical considerations are necessary.
Can you be more specific.
Old 09-26-2002, 03:50 PM
Crippler's Avatar
I was very particular and followed the instructions exactly. Oh and I did use a torque wrench.
So I don't know what caused it, but the aftermarket gasket would be my first guess. I will be disasembling it in the next week or so and will be able to update you on what I find.
So what is word on gaskets. To use aftermarket or not to use
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2002, 08:24 PM
Crippler's Avatar
Also if someone could post a link or list the correct steps for this procedure. I'd just like to compare them to what I have. Just make sure I didn't have poor instructions.
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2002, 08:28 PM
Do you recall the brand name of the gasket set you used?
I guess what I was implying on the preparation was that it's easy to overlook something that seems inconsequential but comes back round to bite you.
Old 09-26-2002, 08:44 PM
Crippler's Avatar
It took for ever and was hard to get all the little bits of old gasket off. So I'm not saying it's impossible that I over looked something really small, but I don't think I did. I'll take a look at my reciept and see if the brand name is on there.
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2002, 09:16 PM
951carter's Avatar
They started making them cheaper here lately =(
The older ones were better
Do not use any sealent, it goes on dry.
Make sure to get off all of the old gasket and clean the mating surfaces with denatured alchohol. Do NOT over torque them. The spec is 13 ft/lbs. I see that your cam cover is powder coated, make sure there are no ridges that can keep it from mating properly.........I would check it with a straight edge.
You are lucky that you didn't end up with an engine fire!!! =0
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Turn up the BOOST!!!
Old 09-27-2002, 12:47 AM
Crippler's Avatar
I thought it was on fire at first, but it wasn't. There sure was a ton of smoke though.
1984 - Porsche 944
1994 Grand Cherokee
Old 09-27-2002, 07:18 AM
951carter's Avatar
I always keep a fire extinguisher in my cars.......just in case!!
I would be real upset with myself if i caused the demise of a P-car.
84 944(sold)
85 944
86 951
87 944(sold)
87 951
88 951
Old 09-27-2002, 07:23 AM
944S Boyeee's Avatar
Send a message via ICQ to 944S Boyeee
The only gaskets to use are Victor Reintz (sp?).
You will get these from most places - don't buy from
Porsche.....they sell Victor Reintz stuff, but at a higher price.
944S Boyeee
Old 09-27-2002, 07:33 AM
overkill's Avatar
Send a message via AIM to overkill
You know what would be sweet an emergency fire extinguisher system under the hood. They make those right? Im sure. One hit of a button and BOOM fires out!
{1987}944S - (SOLD).
Old 09-27-2002, 08:22 AM
ae1969's Avatar
Send a message via ICQ to ae1969
more than likely it was not torqued properly....
The torque used on the cover is so low.....any debris/oil/crap in the holes definitely affects how good of a seal you obtain....
When I removed mine....I could have turned the bolts of by hand.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-27-2002, 03:51 PM
