Which A/c compressor is this one?
I received this compressor from a supplier on HK.
It seems to be the same body as the Nippon 10p15e that we use, but mounting points seems to be on a different position.
Anyone know what model uses this compressor, of if I can use it on my 85.5 adapting the lines. Mounting points for early 944's are different than 85.5?
Any help is welcome!!
Old 08-01-2014, 06:52 AM
It appears (if an 85.5 is the same as the later 944's and 968's) that it is missing a mounting ear on it. There should be two (one on each side of the blank off plate), one for the forward upper mount, and another for the upper rear mount.
I just replaced my 968 compressor because I broke a mounting ear off, here is a picture:
Here is a detailed thread with lots of pictures:
AC Compressor Replacement - Rennlist Discussion Forums
HTH!
Old 08-01-2014, 07:56 AM
kuehl's Avatar
85/1 and 85/2 are two different animals,
what you got is "almost alike", return it and
buy one from the host, oe pn was 944126008
Old 08-01-2014, 11:53 AM
right compressor for an early car, but the case is 99% likely meant for a Ford of the same vintage.
Old 08-01-2014, 01:31 PM
kuehl's Avatar
almost right compressor for a "late" car, 85/2 but missing ear
Old 08-01-2014, 02:38 PM
