flash968's Avatar
to sum up - better is relative. it's all about how clean whatever oil is.
all things being equal, the amsoil will be better than the others because it is a full synthetic, which would last longer and cost less in the long run.
Old 08-21-2014, 06:55 AM
I've been told castrol and many big name oil brands use a derivative of anti freeze in the oil to reduce temps and make it appear as though it is working, while sacrificing lubrication qualities. I'd stay Far away from castrol.
Old 08-21-2014, 07:07 AM
For me with a higher mileage engine dino 20/50 oil is the best. Running mobil 1 my seals started to seap so I went back to mineral oil and it has been 4 years and the seap has not returned.
I understand, and i appreciate the advice.
what brand of 20w50 dino oil do you use?
Old 08-21-2014, 07:13 AM
FLYGEEZER's Avatar
I have to say a lot of the "jibberish" in the last three pages of post will not offset the good performance my 135,000 mile 944 has given to it's two ownership life using ONLY Shell Rotella SAE 10W40 dino oil. The first oil change at the dealership, when new, at 3000 miles has always been the same, no additives ever. No oil pressure issues, no leaks, no lifter noise. Can't argue sucess. Same goes for my old MB , It's at almost 190,000 miles. All old german n/a engines like dino oil. If I ever by anything "new" I would use Mobil 1. Oh yea, Shell Aero (dino) in the Tri-Pacer.........1800 hrs SMOH, no problems.
Edgar
1984 Porsche 944 bone stock
1995 Mercedes E320 wagon
1970 Honda CB350 mint!!!
Old 08-21-2014, 07:57 AM
smokin_944's Avatar
I guess my situation is different because I only drive my 944 in the summer on nice days but I've used Mobil 1 15w-50 syn for the last 10 years. I have no oil pressure issues or leaks nor do I have lifter noise. My car presently has 175 K. Mobil 1 works for me...
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 08-21-2014, 08:16 AM
I used Castrol for the first couple of years but my oil consumption was more than using Valvoline so I am sticking with Valvoline 20/50.
Old 08-21-2014, 09:13 AM
Patrick
pfarah's Avatar
JD159,
I'm interested where you heard this...
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 08-21-2014, 09:39 AM
curtisr
curtisr's Avatar
Originally Posted by princej View Post
ok, so. to sum up.
Can we agree that Z-ROD 20W-50 by amsoil is better for my street driven car than Valvoline VR1 racing oil 20w50.
or 10w40 Castrol High Mileage oil?
what about brad penn 20w50?
Yes.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 08-21-2014, 05:54 PM
MDH MDH is offline
Castrol GTX 20w-50 for warm weather,
10w-30 geriatric(high mileage) for cold in the 924s
10w-30 GTX in the Frontier Nismo and the Legacy year around..
No consumption issues...been using GTX for years.
1988 924S
It's still cheaper than psychotherapy...................
Old 08-21-2014, 07:30 PM
MDH MDH is offline
Oh yeah....3000 to 3500 miles between changes
1988 924S
Old 08-21-2014, 07:33 PM
Parrothead member
VINMAN's Avatar
300,000+ trouble free miles running Castrol 20/50 dino in the summer,
Rotella T 10/40 in the winter.
Aint about to change...
Vinny
Old 08-22-2014, 04:56 AM
Toran's Avatar
Nice!
86 944na Alive and Rollin
Old 08-22-2014, 05:47 AM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Thumbs up Update, Less viscosity is approved and better, not like 20w-50
To All:
Less viscosity Synthetic is approved better and definitely not 20w-50....
Please remember, I did not make this all up! "Jedi Mind Trick"
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 08-24-2014, 09:17 PM
All this smells a lot like silly California smog-regulations. To have the CARB-EO number stamped on your catalytic for legal sale in CA, you need to have it submitted to, tested and approved by CARB. However, just because there's a list of 100-approved products for the CA market, doesn't mean that there's an additional 5000 catalytics that will work just as well. In fact, most of those 100 approved products are the exact same sold in the other 49-states. Just that the ones in Cali has been "approved" by the CARB. The other 5000 will work just as well, they just don't have the stamp.
Same thing with oils, sure Porsche tested X-number of oils and put them in their specs chart. That doesn't mean there's not a tonne of other oils developed after 1987 that meets or exceeds Porsche's requirements.
To really make this discussion worthwhile, please provide a list of objective, measurable criteria that Porsche used to test their oils. Only by replicating Porsche's own tests on newer oils can we know for sure if they do or do not meet those specifications.
Same
Old 08-25-2014, 12:11 AM
Originally Posted by guru944 View Post
To All:
"Jedi Mind Trick"
More like a "Jar Jar Binks Mind Trick"
Good luck, George Beuselinck
Old 08-25-2014, 02:03 AM
Andrew Gawers' Dad
CHICKS's Avatar
To All:
This has NOTHING to do with us. That's from 1997, and for a Boxster.
Old 08-25-2014, 06:18 AM
Lear35A's Avatar
Originally Posted by flash968 View Post
d normal deposits, and nothing to worry about. i don't think they told me how many miles i could go. i can try to dig it up. not sure where i filed it, but i know i filed it.
With Blackstone you don't need to file it. All your reports are available on line.
Lance
'94 968
Old 08-25-2014, 07:28 AM
flash968's Avatar
they are if you set it up that way. i didn't. i don't really do the "online" thing much. i'm still pretty much a dinosaur where that is concerned. i don't even know how to text, and actually have that feature disabled on my phone. i'm now down to only checking email once a day too.
Old 08-25-2014, 07:32 AM
Andrew Gawers' Dad
CHICKS's Avatar
I don't believe it. You got called out for the second time on you BS.
Old 08-25-2014, 07:43 AM
