944 Clutch pedal problem
Hello everyone. I have a 82 Porsche 944 and I recently replace my slave and master cylinder as well as re-enforced my firewall after realizing it was cracked around the master cylinder because my clutch pedal was sticking to the ground.
I just got finishing re-installing everything and I bleeding the clutch (using a power bleeder which makes things so much easier) and checked for leaks. My clutch pedal is still not operating correctly, I messed with the clutch return spring and the master cylinder distance but the pedal still won't come back. What am I missing do I need to mess with the distance so more in the return springs or should I look elsewhere.
Old 08-28-2014, 09:00 PM
Northern Motorhead
wildcat077's Avatar
You might have better luck bleeding the clutch system the old fashioned way,that is with somebody pumping the clutch pedal from inside the car.
It seems power bleeders don't work too well on newly installed clutch masters/slaves !
Cheers
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-29-2014, 06:26 AM
flash968's Avatar
not true at all. in fact, while i agree that vacuum type bleeders don't work (i'd say they suck, but that was the obvious joke) the best way to do it is with a motive power bleeder.
the key is to have the nose slightly higher than the tail, and to make sure to never let the fluid in the reservoir get below the pickup hose.
also, the high pressure line is known to balloon, causing these problems. it fails from the inside, so you can't see the problem by looking at the hose.
Old 08-29-2014, 07:22 AM
Andrew Gawers' Dad
CHICKS's Avatar
You want the ass of the car as high as you can get it. My valance damn near touches the ground when I do it. That puts the bleeder further "up". Watch your fluid level as bleeding.
Old 08-29-2014, 07:47 AM
So the common consensus is that I just need to re bleed the clutch and that it dosnt have to do with the spring?
Old 08-29-2014, 11:10 AM
Bradical's Avatar
The spring doesn't cause the pedal to return upwards, hydraulic pressure in the master cylinder does. Where about in Orlando are you? I find it somewhat ironic that I am doing my master/slave tonight and I live in minneola. I also have a motive power bleeder, just sayin.
Old 08-29-2014, 11:15 AM
I figured but when I removed the spring the pedal returned, also I'm in winter springs
Old 08-29-2014, 12:21 PM
A-HA! I figured it out the rod that attaches the master cylinder to the clutch pedal was not extended out far enough, everything is working now except the car give me trouble when I put it in reverse, the car stumbles, any ideas? Thanks
Old 09-01-2014, 10:02 AM
Tags
clutch , ground , return , stuck , wall
