I have an '89 n/a with the 2.7l engine. I am in the last stage of replacing t-belt, balance shaft belt, accessory belts, oil cooler seal, and etc... The water pump that I took out only had one connection, to the lower radiator hose. Due to this connection the hose coming from the expansion bottle was connected to a small aftermarket hose and into the radiator just above the lower hose outlet. I got a new pump that has a spot to hook up the hose from the bottle (or so I think...) I currently have a cap on that spot. If I make that connection I will be left with a spot on the radiator (which I could place a cap on) My question is how is this supposed to be connected???
1989 944 Grey/Linen lthr |
For the non turbos you have to cap off the "extra" small hole on the front pf the water pump. The rebuilt I got a few years back did have the 90 degree nipple but the inside of the nipple was blocked off.
The vent hose for the o-flow tank goes on the radiator where it came from.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Yeah, I figured it out... Thank you very much for replying anyways!!!
