In the Fires of Hell.....
kdjones2000's Avatar
N/A DME Conversion question
I have an '88 N/A DME (PN ends in .05), which uses a 28 pin EEPROM just like the Turbo models do. This DME is set up for the 10.2:1 high compression pistons that I have in my Spec race car.
Well, the DME crapped out on me during a track day last week, and I have a .04 DME which I believe was used for the '86/87 cars and has the 24 pin EEPROM.
My question is, is it possible to do the 24-to-28 pin conversion for the N/A DME's like you can do for the Turbo DME's? Has anyone done this before?
From what I understand is that the car will actually run OK with the '86 computer/EEPROM, but I would like to use the actual proper EEPROM for the engine if it's possible.
EDIT: Well I took apart the '86 DME this morning that found out that it also uses the 28 pin EEPROM, so I guess it's all good.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-22-2015, 06:19 AM
Was that an original '86 DME with 28-pins? Or a 24-pin that was converted to 28-pin?
Old 11-23-2015, 01:52 AM
The original '86 NA DME I guess has a 28 pin EEPROM. I am surprised since the Turbos only went to 28 pin in the '88+ years.
I don't have too much experience with the NA's, so this may not be 100% correct.
The '86 was a .04 box while the '88 one I have is a .05.
Old 11-23-2015, 05:14 AM
plays with toy cars
sausagehacker's Avatar
http://roguetuning.com/DME_28_Pin_Conversion.pdf
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 11-23-2015, 05:22 AM
