| Vehicle Enthusiast |
				Gauge reading bounce up under load
			I've finally decided to tackle the electrical bugs in my 944  Whenever i put the system under load- headlights, heater, stereo; some of my gauge reading will bounce up, until the electrical load is taken off. For instance, when the car is at almost 3/4 temp, and i turn on the heater while the headlights are on- the temp gauge bounces up into the overheating range (though it is not actually overheating). My oil pressure gauge bounces a little too as well at the same time. Few repairs i already have done: 0 gauge wire from battery to alt and starter new battery new alternator all chassis ground have been cleaned of corrosion- including corrosion inside the wires Anyone know what might be the cause of this?
				__________________ 84' 944- 115K M220 M456 | ||
|  12-28-2015, 10:21 AM |
| Registered |
			Ck...your main battery ground wire that bolts to the back of the block ... it may be frayed and shorting out due to being old and hot! Ron
				__________________ 951 | ||
|  01-01-2016, 04:09 PM |
It was corroded, i've already replaced this with 0 gauge wire too.
|  01-01-2016, 06:11 PM |
| Tags |
| electrical bugs |
