Injectors 924s not firing
When I crank the engine I have fuel coming to the fuel rail but none of the injectors are firing any suggestions on what I can try.
Administrator
Check out this tech article from our site. There might be some dirt in them and a cleaning may fix the issue. Best of luck!
![]() Pelican Technical Article: 944 Fuel Injector Clean & Reseal -Dmitry |
Thank you for your reply I will give it a try however I fail to mention that ice or no voltage at the injectors when I remove them while cranking the engine I do have fuel pressure however
Usual stuff. Tach bounce? Puff of starting fluid? DME relay jumper?
1987 928S4 1992 968 cabrio 2009 957 Cayenne GTS |
Engine runs when I spray starter fluid into throttle body
The harness going to the injectors is a common problem. Look for broken or frayed wire . There is a repair kit availabl . Other then that start checking pins on the control unit harness per Clark's garage.
Thank you I will start checking the harness thanks so much for the quick response
You should hear the injectors clicking if they are getting a signal and they are not stuck. If the car has been stored for a long time the injectors might be full of goo.
A "noid" light or DMM or test lamp or something should tell you if you the injectors are getting a signal to fire. Ticking a few injectors with a test harness should fire them and then the car should catch a little bit if you indeed have fuel pressure. You should be mindful of burning out an injector, just short zaps is what you want like if you want to see if a wire is live.
Great information you guys to give me things to check that I never would have thought of or knew about I am not a car mechanic but I'm willing to try
Administrator
That's what we're here for man! Glad that our input made you want to dive into diy fixes. Let us know how it goes! -Dmitry |
'87 924S
It sounds like you are not getting 12v at the injectors with ignition on? If that's the case, check for voltage at pin #2 on the 9 pin connector on the firewall (near the brake booster). That is the +tive feed for the injectors and idle control valve.
If you have voltage there, your problem is likely a crimp connection where the wire splits to the injectors and idle control valve. The crimp connection is down near the reference sensors/hvac valve. I took off the intake manifold for access to fix it. Just unwrap until you find the broken connection, likely with loads of green corrosion. If, on the other hand you have no voltage at pin #2 on the 9 pin connector on the firewall, you'll need to trace that back towards the DME. |
That sounds like a solid lead. Thanks from a non mechanic who needs it in simple terms. Awesome. I'll let you know what I find
