Banned
Engine compatibility question.
Is the engine in an 86 944 a drop in replacement in a 83-84 car? If not what mods need to be done. Thx. Mark
Old 02-03-2017, 08:01 PM
Custom User Title
mikepellegrini's Avatar
The 86 engine would have a different DME and engine wiring harness. The harness on the late cars goes in through the firewall by the battery compartment, with the DME under the passenger footwell; the early cars it's kinda under the steering wheel, so I'm not sure how you'd route the wiring.
But basically, yeah, it's a drop in replacement.
You could probably get away with using the early harness and DME, but it might not run as well.
I can't think of any other differences.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 02-03-2017, 10:43 PM
The bare long block of the 86 is a direct replacement.
Re-use the wiring/DME/AFM/sensors/hoses/manifolds from your 83-84 car.
The only real difference to be aware of when swapping is the coolant gauge temp sensor mounted in the block. The later style has a sensor with two wires, your early car has only one wire for this sensor. No problem - you just hook up your one wire to one of the 2 prongs on the 86 sensor to make your gauge work.
Otherwise the engine is more or less identical aside from internal details/revisions which do not affect the swap-ability.
Old 02-04-2017, 08:41 AM
Banned
You said "long block"? Should I use the intake off earlier car or leave 86 whole and change sensors from 83 into the 86 engine? I am not familiar with these at all.
Old 02-04-2017, 11:40 AM
To be safe I would re-use your 83 manifolds.
There was at some point a minor revision to the intake manifold between 83 and 85 where they moved a vacuum port.
You could use all the 86 sensors for your 83 car if you wanted.
Old 02-04-2017, 12:41 PM
