MPDano's Avatar
I am sure Alan knows exactly what that Red/Green wire goes to. Calling Alan!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-15-2009, 05:51 PM
vdubr928's Avatar
Looking at the relay and in particular the wire colors on the aftermarket relay harness I'm going with aftermarket alarm system. Looks like the coil lockout relay. I'm 4 days into my first Porsche too but have alot of chops. A beer if we ever cross paths says that wire across the block goes to the coil and the red/yellow wire is the factory coil feed.
Old 05-15-2009, 10:48 PM
Project 928 - 85' S Auto
MajorDamage's Avatar
OK Gents,
NOID light checks out on all 8, starts idle's so so still.. Timing sounds a bit off
Have not hit up the compression test yet
Old 05-16-2009, 10:25 AM
Network Native
Danglerb's Avatar
Noid light means signal to all 8 is OK, but do all 8 make a nice clicking sound?
Old 05-16-2009, 10:27 AM
Yep all 8 sound like little crabs.. I just got them back from being rebuilt and flow matched..
Old 05-16-2009, 11:30 AM
OK OK OK UPDATE............
Since I went through and re checked and double checked all injectors and signal I decided to start the 928 and feather the throttle until it got warm.
It sat after 2 mins and re-idled itself and simply sat and hummmmmed.. I know it’s not 100%, but its enough for me to get wood over........ After all it hasn’t "run" since mid 2006 and I just wanted to hit "warm" so I could change the oil...
WE DID IT BOYS... now on to the next issue.... TUNE UP...
Suggestions..????!!!!
IDEAS?? BUDGET!
Old 05-16-2009, 02:08 PM
MPDano's Avatar
So you did nothing with the relay in question? Just to be clear.
Old 05-16-2009, 04:07 PM
MPDANO..
Nada.. i double checked and cleaned the connections...
Old 05-16-2009, 06:51 PM
Dozman's Avatar
I do have noid lights that plug into our Bosch injector harness's. They come in handy. Great way to determine visually and quickly if injectors are being electrically controlled.
'88 S4
Old 05-16-2009, 06:57 PM
Dozman, ring me when you have a free moment..
616-893-0891
Old 05-16-2009, 08:19 PM
