MPDano's Avatar
S4 Front Calipers on my 81 OB
Hi all,
I thought I would start a new thread on this. I just got some S4 Front Calipers. I do want to verify this with you guys if you can. The part numbers are 20.4564.00 on one half and 20.4565.00 on the other half of the Calipers.
I will be doing the adapters and 993 Rotors, since I don't have an S4 to grab parts from.
I'm debating Powdercoat or one of those Caliper Pint Kits from Duplicolor. Candy Apple Blue Powdercoating on both Calipers were quoted at $120.
These things are huge compared to my stock OB front Calipers.
Here are some pics. What do you guys think?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-02-2010, 06:28 PM
MPDano's Avatar
**Crickets Chirping**
Old 04-03-2010, 05:43 AM
tedward515's Avatar
When I rebuilt the stock calipers on my 81 us, I used high temp paint and its been holding up very well for about a year now.
89 928 S4 5spd project
81 928 5 spd gone
84 928S 5 spd euro gone
71 911T gone
83 944 gone
Old 04-03-2010, 11:05 AM
MPDano's Avatar
Ok, today is the day to take them apart. OMG! Are these bolts welded on? I was able to loosen the huge allen bolts (4). I am having problems with the 4mm bolts that holds a metal plate on the inside area of the caliper. I tried PB Blaster, torch and even went and bought the 4mm hex head to socket wrench. It aint budging. Any ideas?
Old 04-04-2010, 02:25 PM
MPDano's Avatar
Ok, now i read somewhere that it is highly recommended to "NOT" split the halves. WTF, this throws Powdercoating out the door. I think I will just use some paint remover and remove the paint and do the Duplicolor Caliper Paint Kit in Blue. Cheaper too at $20. Probably will need two boxes.
Old 04-04-2010, 06:36 PM
MPDano's Avatar
As you can see from the pics of when i first got the calipers, they look like crap. After some research, I found out a lot of people were putting clear over the calipers to get them to gloss up. The stock calipers are Black Anodized from Brembo, so I just used some Aircraft Paint Remover and they are cleaning up nicely.
Made a decision to use the G2 Caliper Paint Kit to color the calipers Blue. Speed Bleeders in their future too.
Old 04-08-2010, 08:04 AM
Where did you buy the adapters to be able to make them fit onto the hub? Or will they just pop right on?
Porsche 928 -82 One owner family before us!!!
Porsche Boxster -97 Arctic Silver
Porsche 996 4S -02
Porsche 928S Euro -81
Old 04-08-2010, 08:51 AM
MPDano's Avatar
I didn't buy the adapters yet. They got them at 928 intl.
Old 04-08-2010, 11:55 AM
928s's Avatar
Well my calipers used to look like that, just add paint!
Old 04-09-2010, 01:18 AM
MPDano's Avatar
Wow, nice! Is the top one, the rears? They're huge!
BTW, did you also use the G2 Paint?
Old 04-09-2010, 06:06 AM
928s's Avatar
Yes they are huge, yes I did use G2 paint but only as the etch primer. The calipers were totally stripped but stripped chemically and not sand blasted like I just saw a set. They were ruined by the blasting so don't do it that way. Use the G2 as your etch and base coat. Then you need to use the Glasurit with the high temp hardener just on the top coat. I have had great success this way.
The G2 BTW is no where near the correct color, also depending on how fussy you are make a jig to hold them during painting, this will make your life easier, trust me. Limit the hardener as that is what yellows to a minimum and have them in the hot sun or oven, that is another area the jig is handy.
I showed the larger caliper for purposes of demonstration of the color match, the fact you can get it spot on. The calipers are for 394 mm discs and are 6 piston. Even the rear calipers are bigger than the biggest brakes that came on a 928 at 350 mm.
Old 04-09-2010, 08:40 AM
MPDano's Avatar
Ok guys, I need your opinion on this. I removed all the grime and clear that was over the stock Black Anodize. I ended up using the G2 Paint and feel it came out sub-standard in my opinion. The cheap brush included left lots of brush marks. I shoulda used a thinner bristle painting brush, but oh well. Temp environment was optimal too.
Anyways, my question for you all:
Would you install as-is or would you re-strip and re-paint?
Here are some pics:
This is the first coat and instructions did say these bubbles will occur
Old 04-27-2010, 07:15 AM
MPDano's Avatar
This is the finished product after 2 days drying time. I also sanded the words Porsche down, and if I decide to keep as-is, I will put a high temp clear over the letters and stripe.
Old 04-27-2010, 07:17 AM
tedward515's Avatar
Of course its whatever floats your boat but I think I would strip and repaint. Although the finished product looks pretty good, honestly better than I would have expected for something that was brushed on. In the long run I think it would bother me.
Also if you don't think that you'll be happy the way they are, then now is the time to get right while still off of the car, instead of your car off the road
81 928 5 spd gone
71 911T gone
83 944 gone
Old 04-27-2010, 09:12 AM
MPDano's Avatar
Good points. Also, it will be awhile before I put these Calipers on my car as I am still lacking all the Conversion Pieces. I am still running my Stock Brakes for now. Since I had a lot left over paint, I did the G2 on my Stock Rear Calipers.
Old 04-27-2010, 09:24 AM
MPDano's Avatar
Sheesh, I thought for sure sure I would get more than 1 reply since this morning
Old 04-27-2010, 08:35 PM
tedward515's Avatar
Are you planning on staying with your phone dials? I'm interested because down the road I would like to add the s4 calipers as well. I like the phone dials and from what I gather you need to use a couple mm spacer on the front for them to clear the s4 calipers.
81 928 5 spd gone
71 911T gone
83 944 gone
Old 04-27-2010, 09:08 PM
928s's Avatar
Sorry to see Do not pass go do not collect $200. Now I wasn't going to say anything, my mum says if you have nothing nice to say don't say anything at all, but since you insisted.
Seriously if you would have said you were using the brush, I believe the brush is just for cleaning in the cracks not for painting. I would definitely strip them and put it down to experience.
Old 04-27-2010, 11:41 PM
Network Native
Danglerb's Avatar
Bleh, doesn't look that bad and it is going UNDER the wheels and will be getting dirty fast. Put them on as is and see how it looks in few hundred miles. Suppose you put in all the strip and painting work and the paint doesn't hold up well? Better to find out without all the work.
Old 04-28-2010, 12:59 AM
MPDano's Avatar
Yes, I love my PD's. I also heard the same but I heard it's not all the time. I will for sure post my findings when I get it all mounted.
Old 04-28-2010, 05:03 AM
