Rockin' NW Arkansas
Rear Suspension help neeed.
Ok some of you followed my post with pics of my rear contol arm breaking.
Got a replaceent and it is now in. The guy who installed it says that now the rough ride may be cause by some rubber tat is bad "at the top". "like a U joint". Now im looking at the breakdown and im not seeing this. Anyone? Trying to fixthe very rough ride in back. visible rubbers all look good.
Matt 1986 Porsche 928 S - Daily Driver 1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD |
928: Serial Enabler
A picture would help. At least get the guy to circle what he thinks is causing the issue on the diagram.
84,85,86 928 cars |
Rockin' NW Arkansas
ya he's out of town til monday night. i may not be able to see him till late in the week. was hoping to order parts befor then.
Petie3rd
maybe one of the shocks has a damaged piston or outer casing
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Rockin' NW Arkansas
no it was a muffler/strut shop. he aid they looked good. just 1 side had a bushing that looked like it needed to be replaced
I have the entire rear suspension renovated and out of the car - let me know if you need any details/pics.
I have an 84s as well. When installing the pin that connects the spindle, lower control arm and strut, there is a large washer that will go between the spindle and the shock. I am not talking about the cone washers in the spindle. If this washer is not in the correct place, shaking will occur which seems like a tire out of balance. Thats what I experianced at least. Hope that helps.
Rockin' NW Arkansas
Petie3rd
see post 4
to check the shocks, (just in case) open the hatch, push down hard with all your weight on one corner, then the other. the car should move up and down without any binding.
It could be that the control arm is seized or binding as well. try to isolate. Undo the shock and move it out of the way and see it the arm moves freely. It has to be one or the other.
Names Brad, Canada, Fort McMurray. Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476 |
Well, I guess I have the same problem with mine, new boge all the way around, did not replace the upper mounts. More of a rough ride than I expected.
I cured my super-rough ride by jacking the car and letting the wheels hang for a few hours three or five times.
The more I did this (I was working on other stuff under the car), the softer the ride became. It was like the shocks were seized, but forcing the suspension down through their lower range helped wake up the shocks and and now the ride is superb. Didn't cost me a thing. This is my theory, at least.
1982 Porsche 928, Auto, 4.5 http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945 |
