Love the car!! That is a fine automobile. The shot from the front is killer!!
Need help on this. I just got my Fuel Distributor back from being rebuilt. Now I can't even start it without putting fuel down it's throat, and even then it's a struggle to keep it running.
The FD worked fine before I shipped it out except it had a slow throttle up hesitation issue. I just put the FD back on and didn't do any adjustments on the A/F or Idle Screw. Re -builder told me he did a bench test and all checked out. I got this answer the day he shipped it but haven't emailed him yet about this issue after the re-install. Any thoughts on the video?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Hey Leo,
I feel for you and can relate. Maybe it was adjusted (A/F) to compensate for the elderly FD and now the FD is back in spec (hopefully) and the A/F needs to be matched to the new FD. I can't get mine to run right so no reason to listen to anything I say. I bet you'll have it fixed soon because you are such a smart guy. Wish me luck, I am leaving now to drive the car 2 and 1/2 hrs away to SITM. The wife and kids are going to follow me in another vehicle in case my shark blows up, wheels fall off, steering wheel comes off or locks up, etc,etc,etc.... We had fun thinking of all the dangerous things that could happen with the car if I had the wife and kids loaded up in it for a road trip. It still bogs out bad when I give it more than half pedal but I can cruise along fine but can't use WOT.
82 928 Euro S 5 speed, sport seats,Moss Green/Champagne 04 996 C4S conv tip Polar Silver/Metropol blue |
Here is some replies I got from the Rebuilder.
What's the status of your warm-up regulator? Hasn't this car been sitting at the paint shop for a year? The WUR may have gotten plugged up during that time. I'd make sure the cold and warm control pressures are reasonably in spec first.
Luis 1981 928S Euro 5sp |
Hi Luis,
WUR is fine. Car was up and running prior to removing it 2 weeks ago to ship it to the re-builder. I did do some A/F Adjustments this morning with no luck. Next I will bleed the system in the order given by the Re-builder as well as the WUR, even though I don't think this is the issue.
Exactly why I am not buying that troubleshooting procedure the Rebuilder suggested. I think something is not right with the FD itself. Can't mess with it this weekend so it will have to wait.
How's the FD problem going? By the way I had the same low fuel warn light problem as you and will now unhook my yellow wire and see what happens. Gunar
The FD is still an issue. I pulled the System Pressure Screw to see why my System Pressure was a little low and there were no shims. Although I don't think this is the main issue, I'm going to give it a try this Sunday when I have time. Then I will send it back to the Rebuilder.
Last ditch effort before I went psycho on my car, Rjm65 suggested to move my A/F Clockwise while the Fuel pump is jumpered till the Injectors started to make the singing noise. Did that and then went Lean 1/4 Turn. From my old A/F setting to the new setting was about 3-3/4 Turns to Rich. Cranked it over again and Walla! That was it! She idles like a champ. Waited till I got to operating temp and then adjusted the A/F to about 13.5 Just goes to show that the easy stuff is what we always forget. "Always go back to the Basics." Still can't figure out the slow throttle up hesitation issue, which it still does. Now I just have to put my Smog Pump Belt back on and adjust my front shocks up about 1/2 inch. Then it's off to the Smog Station.
Yes, clockwise is Richening. Not sure on the PSI but before it was just under spec and now it's within. My Euro never had bogging at WOT, just at idle up slowly it would hesitate.
Hence, why I kept telling you to either replace your FD with one of the Black ones or maybe send it to that Rebuilder place and have them Rebuild and Set your Adjustable parts to Spec. He's closer to you so turnaround would be a lot faster for you. I also didn't have time to drive it yesterday, but will give it a road test after work.
The Euro is going to work with me tomorrow, then possibly straight to the Smog Guy after work. Still getting hesitation but I am going to just go for it. Timing is back to spec and it idles ok. The main thing I looked for in my old Smog Test Pass Sheet was the rpms they will test at for 15mph then 25mph and my A/F looks ok at those speeds, so we'll just have to see.
Wish me luck.
the saga is nearly over...
That's great Leo, I hope to hear good news from your test Thursday night...Your car deserve legal California status after all the work you put into it...
I remember when you picked up the then red machine, which you completely restored...seems like just yesterday... Hey Leo, what brand of gauges did you get for your black 928? I like your blue air/fuel gauge. I am interested in getting a three gauge setup for my car, and basically removing the radio, I was thinking: Transmission temperature Air Fuel Engine Temp (not sure which though)
_____________________ Al - Carlsbad, CA -84 Porsche 928S- Auto "US" Black paint/Black int. -71 Jaguar XJ6 White paint/tan int. -03 BMW 525i Light Blue paint/tan int. |
Thanks for the thoughts!
Here she is, hanging out on the side street parking near my work. Next stop, Smog Nazis.
What do you guys think of the Front Wheel height? I think I raised it too high. What do ya think? ![]() ![]() ![]() ![]() ![]()
Recovering dismantler
Very nice Leo - but does look a little high. On both my cars here the ground to arch height is right on 25 1/4 inches, and they do look better IMO.
Neil 2009 Mini Cooper 2004 Mercedes CLK500 2024 Subaru Outback Touring XT 2020 Entegra Coach |
