I used a lift like the one pictured in this thread to pull my 928 engine(s) without difficulty. I used it in the most extended position from the front of the car. I used a chain between the 2 engine lift points. Before removing the motor mounts and removing the bolts from the bellhousing the hoist would actually lift the entire front of the car. I don't recommend that by the way, I suspect it is hard on everything, but it was an observation made using my lift on a scrap engine and a test of how robust the hoist really was...it passed.
And as others have suggested it is possible on my hoist to extend it another 6" and drill a new hole in the arm for the lock bolt. Certainly not OSHA approved..hence my lifiting test above....and I did use both the support legs....
1956 Intermeccanica 356 Speedster (sold),1957 Intermeccanica 356 Speedster (sold),,1985.5 Porsche 944 (sold),1955 Thunder Ranch 550 Spyder (sold), 1955 Outlaw 356 Speedster (currently in build out), 1984 Porsche 928S (White), 1984 Porsche 928S (Red)
Old 01-14-2011, 04:15 AM
Madman
OK I got the fender off; yeah I just had to pull harder to break the sealant glue stuff. Happy to not find rust underneath considering the amount of leaves and other S* in there.
I've also removed pretty much everything I need to for the engine removal, I just have the motor mounts, four bolts in the "bell housing," and the drive shaft link.
Fender removed:
Drive shaft/pressure plate:
1979 Porsche 928 3sp auto, black (gone)
Yamaha FZ6R, Raven Black. (gone)
1997 VW Jetta GLX VR6 swap in. black (gone)
1988 Jeep Cherokee 4.0 lifted, mudders, roll cage, black (wife's)
Old 01-14-2011, 07:11 PM
Madman
OK, so I got the engine out yesterday and attached it to the stand today. Hoping to start disassembly today also.
Old 01-18-2011, 07:51 PM
