928 no speedo, battery, fuel, etc.
I have a '82 928...the RPM work, but the speedometer, fuel gauge, battery gauge, etc. doesn't work. Any suggestions what to look for or do?
thanks in advance... |
Engineer of profanity
It's probably the connections to the speedo cluster. There are three plug in connections to the cluster. You will have to pull the binnacle, and check the plugs. If they are plugged in, you might need to clean the contacts where they plug in. Sometimes the speed sensor goes out or gets dirty. It clips onto the very rear of the transmission with a screw and a pin. Usually that is the problem when ONLY the speedometer doesn't work. When one side of your cluster goes out, it's usually a bad connection to the cluster. The fuel guage is probably the electronics that connect into the fuel tank or the fuel level sending unit inside the tank. They are accessed under the rear carpet in the back glass. The cover is right on top of the fuel tank. There is a connector that plugs in under a fiberglass sheet directly under the carpet.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black Last edited by 924CarreraGTP; 02-21-2012 at 07:04 PM.. |
Network Native
Plan on cleaning contacts, ground points, etc. If it hasn't been regularly, its needs to be done.
Thanks guys! I will will try cleaning the points, etc. and let you know what happens.
Here, check this thread. Many don't like my scalpel method but everything on my Instrument Cluster works.
http://forums.pelicanparts.com/porsche-928-technical-forum/607208-most-common-928-issues-fixes-2.html
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
928-Electrics Guy
Do your interior lights work?
Alan
1994 928 GTS Black/Black Manual |
928-Electrics Guy
I was asking the OP... try testing / changing fuse 12.
Alan
1994 928 GTS Black/Black Manual Last edited by Alan in AZ; 02-23-2012 at 06:19 AM.. |
hmmmmmm same problem w mine . my tach, temp n oil work fine, no speedo , no gas guage,
Network Native
Bad speedo connections are the main reason I think its still possible to find low mileage 928's.
Sensor can apparently fail back in the tranny (not really sure about this being common). 4 pin connector in the top front of the spare tire well needs cleaning. Pins on the pod connection fingers need cleaning. Ground points need cleaning. Flexible circuit boards need replacement and/or cleaning and/or resoldering. Fuse Alan mentions above. Assuming all electrical works, a gear in the odometer commonly fails. |
my speedo did work for a few sec, once. it went up to 40mph then back to zero, that was all it ever did
Davetr, The speedo not working is either the sensor on the very rear of the transmission that may just be dirty or loose. Next try the connector just in front of the spare in the right corner of the spare tire compartment. If not fixed it's the speedo connections, or the speedo itself. That connects the sensor to the trans. The fuel guage is the sending unit that I explained above unless it's the combination of that and other contacts. The fact that you said it worked for a second kinda says it's the rear trans sensor. At least in my experience it does.
1970 Porsche 911T Black 1990 Porsche 944 S2 Red on cashmere 1984 Porsche 928S Euro ROW GP white on black |
