European Shark
riber.bentsen's Avatar
How do you swap the ignition lock?
Well, the title says it all, really.
The ignition lock in the '78 is very worn (key can be removed while the engine is running) but the one in my '86 parts car is fine, so I want to swap them.
Can you just swap the ignition cylinder, or do you need to swap the whole steering column?
1978 Porsche 928 Euro 5spd. Silver metallic/Black
1986 Porsche 928 S2 Euro 5spd. Meteormetallic/Grey. *Crashed*
Owning a 928 is risky business - but sometimes you just gotta say "what the fudge".
Old 07-07-2014, 05:50 PM
The ignition cylinder can be removed but it requires removal of a split pin on the top of the column.
Old 07-07-2014, 06:38 PM
tazzieman's Avatar
It's a bit fiddly but not too hard. You'll be fine!
http://forums.pelicanparts.com/porsche-928-technical-forum/416976-replacing-ignition-lock-cylinder-80-928-a.html
928 Tips
Ignition Key Cylinder Replacement
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 07-08-2014, 04:27 AM
European Shark
Thanks guys, I figured it was the split. Doesn't look too hard, nice project for tomorrow
Old 07-08-2014, 10:28 AM
928-Electrics Guy
Alan in AZ's Avatar
You may want to take apart the old lock and see if you can restore action so you can maintain the same tumblers and a single key for everything - you could swap the barrel & body from the spare lock and see if the tumbler pins are still good enough to reuse?... you may even be able to use some of the replacement ones. It may also just be some broken/stuck springs...
Much more convenient to have one key...
Alan
1994 928 GTS Black/Black Manual
Old 07-08-2014, 08:26 PM
European Shark
I'm changing the door, hatch and glove compartment locks as well, so I'll have one key for all
Old 07-09-2014, 01:02 AM
928-Electrics Guy
Alan in AZ's Avatar
Thats' a lot of work...!
Alan
Old 07-09-2014, 07:51 AM
European Shark
Nope, not really. I'm swapping whole assemblies, so actually the only tough one is the ignition.
Old 07-09-2014, 09:00 AM
928-Electrics Guy
Alan in AZ's Avatar
The hatch is easy apart for the fine tuning of the lock realignment... the doors - not so much.
You have to get into the door and past the protection plate... I'd not rank this as a fun project - allow about 2 hours per side.
Alan
Old 07-09-2014, 09:36 AM
I think you can send the original key and the new tumbler to 928 Intl and they will match the new tumbler to that
key.
Old 07-09-2014, 02:12 PM
European Shark
Lock realignment? Why? I just removed the allen screw, popped out the old lock, put the 'new' one in, replaced allen screw. Works beautifully, two minute job at the most... But this is non alarm locks and vacuum assisted, so may be simpler than the later ones.
Old 07-10-2014, 01:02 AM
