Dean_Fuller's Avatar
14 pin connector broken
After removing to clean a couple times the connector on both male and female sides have cracked and fallen apart in my hands. I have checked with a couple suppliers and they are over $40 a side. Just too much for a plastic connector. I am thinking about using separate connectors and layers of shrink wrap....or just solder all of them together permanently .
Has anyone done this??? I don't see a problem with it and if made weather tight...may solve the corrosion issue.
I am NOT paying $90 for a new plastic connector.
1980 AUTO Synergy Green Metallic / Black & Grey ( my son's)
1989 Auto Slate Grey Metallic / Cashmere & Black (mine)
1982 5-speed White / Black sport seats ( brothers )
Old 07-01-2013, 01:03 PM
Kool
AirtekHVAC's Avatar
I asked about creating a different type of connector, early on, and did not get really good feedback. Seems like something better could be made.....
Ron
1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project
1982 5sp resto project, 1985 Auto S3
1984 Parts car (the fire car) 1987 s4 (parts, or maybe project)
(Yes, I now have 4 project Sharks)
Old 07-01-2013, 04:33 PM
harborman's Avatar
By the time you get done trying to change out the connector you might be better off spending the $90 and replace with stock.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 07-02-2013, 05:50 AM
78cal928
cal928's Avatar
here is a possible substitute:http://www.mouser.com/catalog/specsheets/H59016_K3.rev1.pdf
Old 07-02-2013, 06:54 AM
tisilrad's Avatar
how about using GM weatherpack connectors...you could get enough of them to make every connection different and it is readily available. You might even find one with 14 pins on a wrecked GM vehicle. Try the main engine wiring harness connection.
Heraclitus: 1987 porsche 928S4 5 speed black/black moneypit
Old 07-02-2013, 07:09 AM
The GM weatherpack connectors look PERFECT!!! THANK YOU!
Old 07-02-2013, 07:34 AM
I am going to try using Delphi weatherpack connectors. They are TRUELY water tight, vibration and heat resistant. 2 6-pin connectors are $14.00 ( 3 pins not used on a 1982 model )... Hopefully no need to clean every year too. I may retro fit ALL the under hood connections with these as other are falling apart in my hand.
http://www.ebay.com/itm/Delphi-GM-6-Pin-Weatherpack-Connector-Kit-16-14-AWG-/230864494085?pt=Race_Car_Parts&hash=item35c0989e05&vxp=mtr
Old 07-02-2013, 10:24 AM
whatudrivin's Avatar
Dean, I believe Carl at 928 motorsports can rebuild an entire harness, if you wanted to spend that much.
\Brad/
'82 928 Automatic w/Competition Package Black/Red
Old 07-02-2013, 12:54 PM
Kool
AirtekHVAC's Avatar
Dean, please let us know how that works....
Ron
Old 07-02-2013, 06:36 PM
928: Serial Enabler
You can omit the connector and solder the wires directly, too.
The only time it comes apart, anyway, is to clean the damn thing.
Old 07-02-2013, 06:50 PM
tisilrad's Avatar
yeah, I plane to eventually replace all my connectors with weatherpack i am collecting various connectors by stripping wrecked GM cars when i drop by my friends junkyard.
Old 07-02-2013, 07:12 PM
SanDiego928's Avatar
I just did this last weekend. Weak link gone in my old 2k 928.
Mark
1981 928
Old 03-11-2015, 09:04 PM
Find a local pick your part and keep it original
Old 03-12-2015, 06:07 PM
stepson's Avatar
So now you are one those POs that everybody can complain about and curse for not correcting the problem but instead adding to a later-down-the-road problem.
John Curry (Drift King) 928OC member
Grand Prix White 1994 GTS AT (The GTS)
Black 1989 GT (The GT) and Cobalt Blue 1989 S4 AT (The Blue Car) 1986 Euro AT
Indishrot 1984 Euro S AT (The Stepson) and Black Metallic 1984 Euro S 5 speed (The Schwartz)
Old 03-12-2015, 07:18 PM
928-Electrics Guy
Alan in AZ's Avatar
Most of the connections there can use a simple regular weatherpak - the starter connection (yellow) cannot - it need a bigger connector than the rest - it carries a significant current!
Permanently soldered wiring is a real issue if the engine ever needs to come out...? Why do that - these connectors are cheap and easy to use.
Alan
1994 928 GTS Black/Black Manual
Old 03-12-2015, 08:31 PM
Guess so. Its cool.
My car is better today than when I received it. And with the parts from 9 2 8 intl. I received today I can fix my steering and pass smog.......... I am happy. Poor but happy.
Mark
1981 928
Old 03-12-2015, 09:09 PM
Network Native
Danglerb's Avatar
Isn't the 14 pin used in some other location?
Not a place I would attempt to save money on.
Old 03-13-2015, 06:35 PM
