Tip swap to 5 speed
Anyone do a coversion from tip to 5 speed. I don't use my car as a daily driver anymore and I'd like to pop in a 5 or 6 speed. Its a 94 C2. The car is really REALLY nice and I don't think I'd be able to find another like it as it took me 7 months to find this one when I was looking!
Any help would be appreciated.
Old 11-17-2004, 05:08 PM
When I was looking to buy a 964, I found one that had been converted and the owner said it was a piece of cake. Best part is, you get the OBC in the tach as standard equipment. Bummer part is you have to swap your speedo (and document it) for a 5 speed version. This itself may raise eyebrows in the event you ever sell it.
Hope this helps...
Old 11-17-2004, 06:18 PM
WydRyd's Avatar
Hmmm, interesting topic.
With the prices of 993's dropping so fast down-under (especially Tiptronics), I may be in the market for one later next year
If I find a good Tiptronic relatively cheap, I'll swap out the Tip for a 5/6 speed manual and Twin Turbo the sucker
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-17-2004, 08:07 PM
Why do you have to change the speedo ?
92 964 RSRish project
01 996TT
95 325i
92 318i
etc, etc, etc
Old 11-18-2004, 04:27 AM
hallo
You dont have to change the speedo ,the gearselector just wont work .
i have done this 2 times now and it is not a piece of cake . You have to change a lot of things ,not only the pedals/Shifterconsole/Gearbox .
Also the flywheelsensor,Flywheel( good reason for RS Flywheel ) Clutch,
rearlight switch/cables ,throttleflap ,etc.
You sure spend 4 K on used parts with a 5 Speed and 1-1.5 k more for a 6 Speed .
If you do the Conversion go with the 6 Speed and the RS flywheel .
harald
Speed
Old 11-18-2004, 02:40 PM
