fixed wings for 993
Does anyone know of an aftermarket fixed wing for a 993 that does not require drilling visible holes in the original decklid? In otherwords, I want to be able to remove the wing in the future and put the OEM mechanized tail back in the opening and not have holes showing in the decklid?
Old 11-13-2009, 09:38 PM
Max Sluiter
Flieger's Avatar
Why not just get a fiberglass Burzel? You would unbolt the stock lid from the hinges and swap the whole panel. There would be no additional holes and the panel would look smoother and be lighter and stronger than an add-on.
Old 11-14-2009, 12:38 AM
Bill Verburg's Avatar
any of the factory insert wings will do, RS, RS/CS, aerokit 1 or 2. I haven't mounted an aftermarket but I believe that the aftermarket copies of those wings mount the same.
here's a factory RS wing
Bill Verburg
Old 11-14-2009, 05:32 AM
Mammalian
96740's Avatar
2007 Cayman
Old 11-14-2009, 02:04 PM
Originally Posted by 96740 View Post
I don't think that one will work, the rear wall is past the insert area it looks they made room for an intercooler. Oem's all just bolt to the insert area.
These are oem RS/CS
Bill Verburg
Old 11-14-2009, 03:23 PM
