Ignition System Test. Now what?
My 1990 C4 idling is erratic when engine is cold. The idle would drop about 300-400 rpm and back to 900-1000 again. This would cycle for about 10-15 mins. I cleaned the ISV, checked vacuum leaks, replaced cap/rotor and airflow meter as well. But the problem was persistent. Valve job just completed 3K miles ago with new plugs/wires. The last mechanic said the car is logging code 41 and 34 and to just live with it since it runs well when engine is warm. So when I got home I tested the ignition system and here's what I found.
TEST #1: I tested the coils by switching the coil wires from the distributor side. When I disconnect the coil wire #2 from the secondary distributor (away from fender), idle was okay. But when I disconnected the coil wire #1 from the primary distributor, the engine would ping/misfire. I then plugged the coil wire #1 to secondary distributor to see if it would have the same result. The result was the engine would crank but not turn over to start. It didn't matter whether coil wire #1 or #2 that I plugged into the secondary dist. The results were either ping/misfire or no start. Test #2: The next test I did was to unplug the rear ignition module connector from respective coil (leaving the fwd connector plugged), the engine ping/misfires. I then took the fwd connector and plugged it to the rear IM. The result was ping/misfires. It didn't matter which IM I plugged the fwd connector, the result was pings/misfires. (On the other hand when I plugged the aft ignition module connector to fwd or rear IM. The idle was okay.) So do I have a bad coil or a bad secondary distributor? Is the Hall sensor in the secondary dist? Last edited by topzy; 11-13-2009 at 03:23 PM.. |
ignition
are you the one that posted this on rennlist? i left my phone number in your box, you are more than welcome to call we can fix this its easy.
ignition system
dutchcrunch,
been having connection issues with rennlist site so i switched over. I couldn't retrieve your info (didn't know which box you're referring to), but I sent you an email via pelican "private" email. Thanks and I really appreciate your help. |
