Is there a trick to pull a tip trans off a 3.6?
I need to pull a Tip trans off the 3.6 engine I bought. All the bolts are out, starter is off. For the life of me I can't see anything holding it all together but the trans won't move but a couple mm, like it's bound up on something. I know the correct way to pull a manual trans off, with the clutch fork having to disengage. Do I need to unbolt the small 5mm allens that look like they hold the torque converter to the flywheel?
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Just wiggles off.
Unbolt the torque converter from the flywheel
That's what it looked like but didn't want to do something wrong. I've never pulled a tip before and frankly don't care to ever again. Some of the trans nuts were at royal pain to get to.
Were you able to separate the trans? To unbolt the torque converter, you have to access the bolts through the starter hole. Rotate the torque converter around until you see the next bolt, remove that one, and so on. After all of the bolts are removed, the trans should separate.
I recently resealed my 91 tip top end and trans separated from engine torque converter stsyed bolted to engine. I had no need to split the cases so just left it that way
If you don't do it this way, you risk, YES RISK, snapping the tip shaft key!
LouZ '90 C2 TIP '08 Cayman S |
