i went through this same nut roll earlier this year, the correct bearings were a b*tch to find.
you'll need 3 each- FAG 7201 BE 2RS AH01 (same as the INA 7201-BE-2RS-AH01) i was able to find only one guy on the entire planet who has these: dirk.schluecking@dswaelzlager.de 165 EUR for the three AH01's you'll also need one INA NX12-Z.... I picked this one up locally good luck! |
Alps Adventurer
Thats about US$205 (CA$240) and a far cry from the $420 (CA$490) quoted in the US.
It was that or nothing in the case of the one I rebuilt for a local owner. His bearings were gone at 112,468 miles (181,000 kms)! |
Didn't see the need..
Al Shkuratoff 86 Carrera, SW chip, Fabspeed, M&K 83SC Platinum - Sold 83SC Slate Grey - Sold |
I took my distr apart a couple of years ago to change the belt and check the bearings. Bearings were still fine at 130k, but I couldn't get it back together without a press because there was so much preload. I left a couple of the shims out and it still had zero end play. Cars got another 15k on it with no problems.
Alps Adventurer
When I look at the distributor I just rebuilt, the insides didn't have a hint of rust on the parts and I mean it looked like it came off the assembly line yesterday, yet the bearings were rusty. Go figure! Yes, there is quite a bit of preload on the both the primary and secondary shaft bearings due to the Belleville washer, which is why I would not use a ball bearing. A ball bearing does not take side loads well which is why I asked Al a few posts up if he had removed any shims to reduce that load. The angular contact bearings need some preload. You can use a drill press with the jaws turned in as a make-shift press. |
Alps Adventurer
I just ordered a set for myself from Dirk, but had them shipped to my Euro address for pick-up there. I just wanted to make sure that source didn't dry up before I had a chance to get some spares. I'll be picking up a slew of them when I am there next summer. He is 8 kilometers off the Autobahn I take every summer. DS Wälzlager & DS Sports |
resident samsquamch
Really great info! Thanks for all your efforts!!!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
Cheers Guy |
Alps Adventurer
Despite available make shift solutions, I'm glad the original bearings are readily available now. I got mine in a few days...
I'd say the credit goes to Jason for the source of these:
Accidentaly rotated the dizzy rotor when replacing. Am I OK? - Rennlist Discussion Forums
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
resident samsquamch
So to be clear, these bearings (#7201....) are the "correct" replacements? No milling or shimming? My car has only 77K on it, but I'm planning to service the dizzy around 85K, maybe sooner, just for kicks.
yes they are the correct bearings and assuming you want to replace ALL bearings.."you'll also need one INA NX12-Z", it's a needle combo bearing inside the bottom end of the primary shaft housing.
Alps Adventurer
We, or at least those interested all knew what the bearing part numbers were, but if you Googled that part number a few years ago, you came up with nothing other than links to other forums searching for them as well. I have to give credit to those suppliers hunting down a source and there are a few of them in Europe. Schaeffler North America is clueless/tight lipped about them for some reason, but I'm not letting them off the hook. |
Alps Adventurer
Is there any reason why you went for the NX12-Z over the NX12?
The NX12 is for oil lubrication and the NX12-Z for grease lubrication according to INA. I can't tell the difference from their on-line drawings. As for lube, of all the ones I have taken apart, I never found a hint of grease in that area, but they were all well oiled.
i replaced what the factory had installed, the part number was clearly visible
"As for lube, of all the ones I have taken apart, I never found a hint of grease in that area, but they were all well oiled." I'm dont see why "oil" would be inside the primary shaft housing? or how it could get in there? the only piece of the dizzy that should see oil is the gear on the end of the primary shaft as it's engaged with the drive gear on the crankshaft...if go back to your first photo, the INA needle combo bearing is the one on the end of the primary |
Alps Adventurer
I found this pic on a 993 forum from a member that rebuilds them. Of course I'd like to confirm that myself. ![]() And then these pics on a bearing manufacturer's site showing the differences... ![]() Not a pressing issue since that bearing is fine in all the distributors I have taken apart, but let me do some more digging. |
Sounds like your machinist isn't thinking clearly.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 02-22-2015 at 07:08 PM.. |
Just a question regarding the bearing above.
The 7201-BE-2RS.AH01 has the following measurements, 12,45x32x10mm The 7201-BE-2RS in the quoted post has 12.4x32x10mm There is an id difference of 0.05mm. Is this bearing still possible to use with no modifications or even heating bearing & cooling shaft? Last edited by Luccia at Pelican Parts; 12-15-2016 at 10:02 AM.. |
Alps Adventurer
