Engine drop
Hello guys,
I am about to drop the motor in order to replace clutch and other components. Yes. this is my first 6 drop. This morning I have put the car on the stands and noticed that's the highest I could get. Please see the pix and hopefully you guys can tell me if this is high enough to take the motor out. I understand I need to remove the bumper at this height. Thanks in advance, BW:) http://forums.pelicanparts.com/uploa...1296425695.jpg http://forums.pelicanparts.com/uploa...1296425727.jpg |
Hi BW, I admire your courage for taking on this kind of task with just jackstands. I am also going to drop mine for a clutch repair but has been procrastinating even though I have a 2-post lift. I finished the rear wheel bearing change though this weekend while the axles were out.
I would suggest that you get the 6-ton jackstands which will give you more lift and capacity and a lot safer than those skinny ones you are using. I will not trust those. How are you going to support the engine? ATV jack or a regular floor jack? The car clearance height will depend on the minimum height of your ATV or floor jack. |
BW
I guess you could find using the search (or will from more reply) the exact numbers but having just drop mine using a scissor lift, I think you need quite a bit more. If I remember from previous reading, its around 40 inches. |
993 instead of a 64 but I think it is close to the same height required. With my jackstands (similar to your front stands) on the highest point and the bumper off I still had to disassemble the ISV to clear on the way out. The jackstands were at 21.5" not sure what that equaled at the bumper but you get the idea.
Have fun with it! Make sure you put your wheels or something under the car when you are working on it just in case. http://i955.photobucket.com/albums/a...halfwayout.jpg |
My jackstands
Minimum height requirement
Thanks for your comment. I think 40 inch is great to be safe. What I have read somewhere says that 37 inch works with the bumper still on the car. I have roughly measured the height from the bottom of the heat exchanger to the highest point of the motor. It's about 26 inches. So considering minimum height of the jack and wood blocks or a board on it, I guess I will need about 32 inches clearance total with the bumper off. Am I right? BW:) |
Your fronts are 7,000 lbs each while the backs are only 4,000 lbs. I had the same jack stands and the thin supports are buckled. I junked them a long time ago. Use the same 3-ton or better a 6-ton JS for the back. Be safe. |
Here is a pic of the car on the Maxjax lift. I will start dropping the engine next weekend for the clutch while I have the axles out when I replaced the rear wheel bearings..
http://forums.pelicanparts.com/uploa...1296474151.jpg |
Js
BW :) |
Hey BW, I finally had the courage to do the engine drop. You had inspired me to do it. This is also my first 964 engine drop.
Tonight, after coming home from work, I started unplugging electrical connections on the left side of the engine. I had to remove the blower assembly to gain access to the rear bracket holding the connectors and fittings. Tomorrow I will work on the right side of the engine. Hopefully by Sunday, the engine is ready to come down for the clutch job, power steering reseal and oil pressure sensor reseal. |
You too?
That's great to hear that you have started as well. I adjusted the height up to 36 inches and drained oil yesterday. But I am kinda scared since I live very close to Hayward fault. I will remove the rear bumper either tonight or tomorrow. BTW, is your C2 Targa or Cab? It appears to be same color as mine which is Amazon green. |
Any special tools needed
Other than jack stands and atv jack, are there any special wrenches or tools that are a must for dropping the engine. Or is there any special tools that if you had would make the job easier.
Thanks |
I measured the engine height from the bottom of heat exchanger to the top and it is approximately 28 inches. If you can get 32 inches from floor to bottom of bumper, maybe you don't have to take out the bumper with your ATV jack set up. I am using a furniture dolly and will just raise the car. Technically speaking, it is not an engine drop, it's raising the car with the engine resting on the dolly on the ground. :D Yes I have amazon green coupe. Hamptonsam, I just went ahead and got started not knowing if I will need special tools. Maybe not. The only challenge i see is the oil fitting in the rear passenger wheel well. Maybe I will need a crows foot wrench or just two big crescent wrenches depending how tight there are. Other than that, I think it will be just regular wrenching tools. |
This is how I got started last night.
Rear blower out of the way. http://forums.pelicanparts.com/uploa...1296643040.jpg Fuse panel on left side, 3 plugs out. http://forums.pelicanparts.com/uploa...1296643099.jpg |
You can also remove the fan\alternator housing during the drop to gain a couple of more inches...
You can do it! |
Hey bazar01,
How are you doing? I have removed the rear bumper and disconnected electrical on the left and top side. I will not post pix today because it is almost identical to your pix(Amazon Green C2). Anyways, I have a question. There are two fuel connections to remove. One at the filter(supply) and others at the left(return). Hope it is not too late to ask but was I supposed to empty the gas tank? Wondering if I have to clamp fuel lines to minimize fuel leak. Thanks, BW |
Hey BW, I have not done much after draining the power steering and undoing the lines. Been working late at work, already to tired to work on the P.
I don't think you have to drain the gas tank. Just undo the left side return and right side at the filter supply line and you should be okay. List of things to do. I already have the half shafts removed during the bearing change. 1. Remove the a/c compressor and move to the side quarter panel. 2. Undo the big oil filter oil line fitting on the pass side. DONE 3. Undo the transmission shifter DONE 4. Unwire the starter and ground to chassis 5. Undo the second oil line hose on pass side DONE 6. undo the accelerator cable (debating whether at the pedal or at the engine) 7. remove HE hoses DONE 8. remove the slave cylinder from the bell housing and move out of the way 9. remove sway bar DONE I guess that's it and should be ready to drop by undoing the transmission mount then the two rear engine mounts. |
I wonder why you would disconnect at the pedal and go through the trouble of pulling the long cable through the tunnel.:confused: Is it easy to undo from the engine? I have not looked yet. |
Easy enough... Its a press fit (pry off with a wide flat screwdriver).
About 18" from the tunnel wall. Off to the 8 hrs in the garage saturday routine :D:):D http://forums.pelicanparts.com/uploa...1296908999.jpg http://forums.pelicanparts.com/uploa...1296909040.jpg |
Thanks JJ, I'll check into that when I get a chance this afternoon.
I already have the half shafts removed during the bearing change. 1. Remove the a/c compressor and move to the side quarter panel. DONE 2. Undo the big oil filter oil line fitting on the pass side. DONE 3. Undo the transmission shifter DONE 4. Unwire the starter and ground to chassis DONE 5. Undo the second oil line hose on pass side DONE 6. undo the accelerator cable (debating whether at the pedal or at the engine) DONE, at the engine + one clip in transmission 7. remove HE hoses DONE 8. remove the slave cylinder from the bell housing and move out of the way DONE 9. remove sway bar DONE 2 more items to do and it's ready to drop. |
Got the starter ground cable off and as well as the solenoid wires. It was still tough to get to the terminals even with the car on lift.
2 more items to go on top of engine. Everything under are done. Starter ground cable. http://forums.pelicanparts.com/uploa...1296944255.jpg Starter solenoid terminals. http://forums.pelicanparts.com/uploa...1296944294.jpg |
I underestimated that when I did mind so it took a little longer than anticipated. |
I already had the shift rod disconnected from the transaxle. I moved the shifter to 3rd gear so it will be separated from the tranny. Is there anything else to worry about before I drop the engine? Let me know. Thanks. http://forums.pelicanparts.com/uploa...1296952734.jpg |
[QUOTE=bazar01;5829294]... I already had the shift rod disconnected from the transaxle. I moved the shifter to 3rd gear so it will be separated from the tranny. Is there anything else to worry about before I drop the engine? Let me know. Thanks.
/QUOTE] Ok So you are just droping the engine not the engine & transmission as one unit? |
Sorry if I was not clear. I am dropping the engine and transmission together.
Isn't your "transmission rod" (disconnected from the shifter) still inside the tunnel or does it clear the tunnel as you will drop straight down?
When I drop the engine and tranny, the tranny end shift rod will clear, so I don't see any obstruction. I should be good.
http://forums.pelicanparts.com/uploa...1296955003.jpg |
Let me think...
I guess that there is a difference between a 915 and a G50 configuration as mine was inside the tunnel before the drop. |
I plan to drop the engine next weekend though because the hydraulic table is not available until next Saturday. |
Almost there
Hey bazar01,
It's great to see your progress. I am being encouraged. Thank you! I have disconnected the shift rod and sway bar this afternoon and will work on the slave cylinder later. A slight problem here, I cannot put enough torque on to the two 13mm nut on the slave so I have decided to disconnect the rubber hose fitting from the hard hydraulic line. It's now lubed with PB Blaster. Also removed the ground cable from starter but wondering if there is an individual ground strap from the tranny like a 914. BW :) |
Good luck next week-end and in a few weeks it might look like this; http://forums.pelicanparts.com/uploa...1296959633.jpg http://forums.pelicanparts.com/uploa...1296959707.jpg |
Actually this is my first one :eek::D:eek: Never own a sport car, never did any mechanical stuff either but thanks to the PP forum and the members, in 2009 I realized a 45 years old dream when I acquire Das Babe. If you intend to do one, do subscribe as many Drop Engine post as you come across. For the cleaning part of it, check my cleaning thread: http://forums.pelicanparts.com/cleaning-detailing-polishing/550748-best-cleaner-bar-none.html |
'JJ 911SC' - I'm learning more about the 964. Only owned it since 2009, have a Bosxter since 2005. PP has done wonders for my confidence and I explore more and more with my car. Members like 'Bubbling well' and 'bazar01' who document their DIY's, (especially with pictures) assist with the learning curve and definitely adds confidence.
Thanks to sharing. SmileWavy |
| All times are GMT -8. The time now is 05:34 PM. |
