telemachus's Avatar
Lightweight Flywheel??
When looking at and test driving a car, is there any way to know for certain that a lightweight flywheel has been installed? Or, do you really need to open it up? Is this something a PPI will verify?
Al
-Black '96 993c2 w/ factory turbo added -poor mans GT2-
http://allanbasik.tumblr.com/
Old 04-01-2012, 10:34 AM
I think that for the "untuned" ear it will be kind of difficult to tell by sound. The motor should rev up faster than the heavier dual mass equipped cars. And, the downside to the LWF is that it transmits some transmission noise. In my car, there is a slite "rattle" at idle sometimes that I believe is the gear noise from the transmission that is wicking through the flywheel and becomes audible.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 04-01-2012, 02:36 PM
Old 928 Guy
surfdog4's Avatar
I've never driven anything but the lightweight flywheel on the 911, but based on other Porsches I've driven you can take it down the road a bit and as you upshift push in the clutch and instead of shifting, watch the tach..if it drops much and rebounds (or even cuts off) you might have a lightweight flywheel.
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 04-01-2012, 05:27 PM
Shamus911's Avatar
There may be a way of telling via the inspection port - anybody know for sure?
KW V3, B&B exhaust, SW chip, RS clutch/flywheel, Walrod & Powerflex bushes, Rennline camber plates, RS heat bypass, RS fog ducts, RS engine mounts
Old 04-05-2012, 08:14 AM
