Clacking noises on the engine passenger side
I noticed this morning when I drove for about 30 minutes. The noise was there even when cold and also when warmed up. It is quite loud.
I m going to put it on the li ft, drain the oil and open the pass side valve cover and peek inside the cam box. Last valve adjust was 30k miles ago. I've heard about rocker shaft walking and lash adjusters maybe. Anything else to check?
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. |
Bandwidth AbUser
Maybe. Or a failed chain tensioner? I wouldn't keep running the engine with that noise.
Jim R. |
Bandwidth AbUser
One more thought, does it make any noise when the engine is running while you car is standing still?
Jim R. |
I was thinking a loose lash adjuster jam nut.
I went ahead and open the passenger side valve covers. All the rocker arm valve adjusters and lock nuts are all tight.
Even the head stud barrel nuts are in tact and nothing fell off. I will go ahead and do a valve clearance check and adjust if necessary. Anything else I should check that is the likely cause of the clacking noises?
ahead of the curve
hows your power steering fluid level ?
19 Carrera T - MPS member 92 C2 SR coupe M491/ 3.8 look- manual 92 C2 SR coupe cobolt blue- manual 73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy 73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
I have not checked it. Thanks Jeff.
30k since last valve adjust? I don't know the 964 specs, that seems awfully long ago.
Short of any glaring issue, that would have been the first thing TO do, IMO. Then, if noise persists, post for help.
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
All head studs still intact. No broken studs or falling off nuts. st I will go ahead and change the spaark plugs and change the oil. If noise persists, I will open the chain box. A few pics. Spark plugs 123 upper ![]() Rockers 123 ![]() Spark plugs 456 upper ![]() Rockers 456
1993 964 C2 still makes me smile Retired and work as needed as a pain in the **s. Last edited by bazar01; 03-10-2013 at 03:01 PM.. Reason: cylinder #4wasloose. |
I did not see anything unusual in the camtower/rocker area that was loose.
how old is your power steering belt? maybe stretched and banging inside?
I changed it at about 30k miles when I addressed the pump cam shaft drive housing o-ring and seals oil leaks.
But I can check the power steering belt and pulleys while the car is on the lift. Thanks.
Put everything back together with new plugs, valve adjusted and fresh oil. Clacking is gone.
Thank goodness it was nothing major. I don;t have to open the chain boxes for a failed tensioner.
